I am using Tmpgenc Athoring Works and wish to convert a series of TV card captures done 2 years ago in SVCD format (480 x 576) to a DVD format. When i input the files into the authoring program i find that the output cli chosen by the program is 704 x 576. I have always though tht DVD format should be 720 x 576.
What will be the output difference on a dvd palyer if i do choose the 704 x 576 setting?
Yes i know i can force a recode to 720 x 576 but can someone please explain the menaing of the present issue?
704x576 is also a dvd compliant size, https://www.videohelp.com/dvd#tech , so it should work fine on dvd players.
4:3 aspect broadcast source works out to 702-704x576 for DVD at SD PAL PAR
720x576 gets you 8 pixel black left and right.
If you stretch to 720, interpolation quality loss kicks in.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
Choosing the best JVC VCR (Pal)
By Acden in forum Capturing and VCRReplies: 6Last Post: 30th Mar 2012, 01:08 -
Need help choosing a program please...
By Drake1132 in forum Video ConversionReplies: 10Last Post: 22nd Apr 2010, 22:32 -
Best tool for PAL to NTSC without jerky motion...using TMPGenc
By funkymix in forum Video ConversionReplies: 3Last Post: 15th Mar 2009, 11:59 -
choosing different background
By snafubaby in forum Newbie / General discussionsReplies: 2Last Post: 6th Oct 2007, 04:07 -
Influence when selecting PAL or PAL 16:9 with TMPGEnc
By Purno in forum Newbie / General discussionsReplies: 4Last Post: 7th May 2007, 04:24
