I'm trying to use Alltoavi to encode a folder of anime episodes in mkv format (to my knowledge alltoavi is the only program that can convert multiple files/folder) to avis but for some reason it stops in the middle of the encoding process and I end up with an avi that is half the size/length it should be. The avi plays fine but is obviously incomplete.
Edit: Tried to do the same with Super but got the same result.
Here's the MediaInfo report on the mkv files:
General #0
Complete name : [Name Deleted].mkv
Format : Mk
File size : 222 MiB
PlayTime : 24mn 12s
Bit rate : 1279 Kbps
Encoded date : UTC 2008-12-26 21:40:36
Writing application : mkvmerge v2.4.1 ('Use Me') built on Dec 5 2008 18:30:05
Writing library : libebml v0.7.7 + libmatroska v0.8.1
Video #0
Codec : MPEG-4 Visual
Codec profile : Streaming Video Profile/Level 1
Codec settings/BVOP : Yes
Codec settings/QPel : Yes
Codec settings/GMC : 0
Codec settings/Matri : Default
PlayTime : 24mn 11s
Width : 640 pixels
Height : 480 pixels
Display Aspect ratio : 4/3
Frame rate : 23.976 fps
Resolution : 8 bits
Chroma : 4:2:0
Interlacement : Progressive
Title : W_B
Language : English
Audio #0
Codec : Vorbis
Bit rate mode : VBR
Channel(s) : 2 channels
Sampling rate : 48 KHz
Language : Japanese
Audio #1
Codec : Vorbis
Bit rate mode : VBR
Language : English
Text #0
Codec : UTF-8
Codec/Info : UTF-8 Plain Text
Title : 2xX
Language : English
	do u teevee?
	does anyone know why these videos won't convert all the way? do u teevee?
  ripbot264/meGui : h.264 stops encoding...By mshilly in forum Blu-ray RippingReplies: 8Last Post: 28th Dec 2012, 05:25
  Megui encoding stopsBy sanosuke in forum Video ConversionReplies: 1Last Post: 20th Dec 2012, 22:36
  BD Rebuilder stops encodingBy pepegot1 in forum Authoring (Blu-ray)Replies: 2Last Post: 25th Jun 2011, 11:01
  AVStoDVD stops working after encoding videoBy tperkins13 in forum Authoring (DVD)Replies: 1Last Post: 19th Apr 2011, 08:10
  x264 stops functioning mid way during encodingBy jones24 in forum Newbie / General discussionsReplies: 4Last Post: 19th Aug 2009, 05:03
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
