Hi all
I am looking into purchasing another DVD authoring program. I currently use DVDIt Pro, but it has recently began acting flakey and the support from Roxio leaves a lot to be desired. I used to use DVD Workshop 2 which is a good program, but the scrubber makes it hard for me to add chapter points easily in imported mpeg-2 assets.
Downloaded the trial of DVDLab Pro 2 and it seems to work OK. I will be using the software for business use moreso than personal use, so I wanted to know from those who use DVDLab Pro 2 for business purposes: Is it reliable? Have you gotten any complaints from clients that the DVD would not play and you had to use another authoring software to get a DVD that would play?
Brainiac
I have been using it for a couple of years and have had no problems with it. I know not everybody loves it, and it's open architecture means, while giving great freedom, there is minimal hand holding.
I would suggest you join the Mediachance forums, where the author hangs out. Here you will find many professional users of the product who can give you their opinions as well.Read my blog here.
Subtitle problem with DVDLab Pro
By carlmart in forum Authoring (DVD)Replies: 3Last Post: 21st Nov 2008, 09:18 -
Subtitles in DVDLab Pro 2
By lorix in forum Authoring (DVD)Replies: 13Last Post: 13th Nov 2008, 14:09 -
DVDLab Pro 2 compile issues
By milofhead in forum Authoring (DVD)Replies: 3Last Post: 27th Oct 2008, 23:25 -
First Play problem in DVDLab PRO
By grzegorz in forum Authoring (DVD)Replies: 5Last Post: 11th Apr 2008, 04:43 -
DVDLab PRO - Music in Menu
By poutniksantiago in forum Authoring (DVD)Replies: 8Last Post: 15th Nov 2007, 07:28
