How to Import and Encode the The MPEG2 TS in Virtual Dub MOD. is there any way to do that...
Results 1 to 9 of 9
Haven't tried to import a transport stream, so not sure. Would probably try a newer version of virtualdub for that.
As for encoding - encoding to what ? Virtualdub doesn't encode to mpeg-2, so you would have to frameserver to your mpeg-2 encoder.Read my blog here.
I need to Encode it to AVC and Xvid... I tried New version of Virtual Dub MOD but it can't work. Let me know there is another Chance to do that. Please
Try Divx Author 1.5 .... works great with MCE 2005 DVR-MS videos
Install AviSynth and DgMpgDec. Build an index file with DgIndex. Use the MPG2Source Avisynth template at the bottom of VirtualDubMod's Open Video File dialog and select the D2V file created with DgIndex.
I remux TS files to plain mpeg2 myself. Then, I can import them to virtualdub with the mpeg2 plugin.
But, avidemux can do that easier. Did you tried it? It even has some automatic solutions for converting to h264 or divx/xvid.
Simple guide for Virtual Dub Mod 1.5.10.3
By s_joy09 in forum Newbie / General discussionsReplies: 35Last Post: 31st Jul 2010, 15:33 -
Virtual Dub Mod video combining?
By wcdeich4 in forum EditingReplies: 1Last Post: 18th Dec 2009, 07:18 -
Virtual Dub Mod Saving Problem
By cdgfx84 in forum Video ConversionReplies: 2Last Post: 1st Sep 2008, 13:08 -
Queue files in Virtual Dub Mod?
By leogeo in forum Newbie / General discussionsReplies: 2Last Post: 2nd Nov 2007, 02:13 -
Virtual Dub Mod
By OG24 in forum Newbie / General discussionsReplies: 11Last Post: 8th Aug 2007, 15:36
