HEY!
I got a biiiig problem! My screen is just black when I start my pc. I get all the boot screens but when you usually see the Vista icon with the little melody I only get the audio!! And then it's just black... It happened today! I'm running safe mode right now... I use a Sony TV monitor... Plz tell me how I can fix this!
	I don't have Vista but I'll take a stab at it.
 I don't want to reboot my computer to check so I'm going from memory.
 When you press F8 to go to the screen where you select the safe mode is there an option that says something about VGA? If yes choose that and then reboot.
 I think I had a similar issue after reinstalling XP once.There's not much to do but then I can't do much anyway.
	I reinstalled Vista about a week ago too.. but now it's got no screen. And does VGA stand for something? Cause my OS is in danish... so a full name would be great! Also I just tried to reset the resolution it worked for 2 mins until I logged on to my user... STRAAANGE!Originally Posted by gll99
	VGA (Video Graphics Array) is the name of the fifteen pin video output port on the rear of your computer and also a compatibility 'mode' on that F8 page.
 Another possibility is you have the wrong or a corrupted video driver. You could uninstall that. In safe mode the installed driver isn't used, just the generic system driver is. That could explain why safe mode works.
 Vista has quite a few video card drivers built into the OS. If you uninstall the one you presently have, Vista 'may' put the right one back in. Then you could go to the video card manufacturer's site and make sure you find the latest or best driver and put that in. Uninstall the driver that Vista supplied first.
 Vista's drivers are fairly generic and don't have all the features that the manufacturer's version does. You should be able to do most of this in safe mode.
	Erhm... Is it supposed to say a standard VGA-device?? I have a nVidia GeForcce 8800GT.................. And it says its a Standard VGA-device and also nVidia drivers autodetect says it...!!! Should I find the latest drivers for my 8800 or just install the one it recommends to me?? I'm very confused!
	Good that you got it solved.
 Sorry I couldn't reply faster but I had to get some much needed zzzzzzzz (different time zone here ). ).
 This is what I was thinking of but this article also explains how to reset the video driver by removing the existing error causing one while in Safe Mode. It's a better explanation than I provided in my sleepy state but both ways probably would have worked although the safe mode option is better.
 http://support.microsoft.com/kb/268852
 It's basically the MS official version of what redwudz suggested to you.There's not much to do but then I can't do much anyway.
  Blank screen when playing video on 'full screen'By RAYPEV in forum Newbie / General discussionsReplies: 6Last Post: 4th Aug 2011, 20:40
  DVD Lab Pro, help mixing full screen and wide screen.By stantheman1976 in forum Authoring (DVD)Replies: 4Last Post: 31st May 2009, 18:23
  LCD Screen: video plays on desktop but appearing black on big screen...By Heyjoojoo in forum Newbie / General discussionsReplies: 2Last Post: 23rd Jan 2009, 18:36
  DVD picture doesn't fill screen on new wide-screen TVBy ibzomie in forum Newbie / General discussionsReplies: 7Last Post: 16th Aug 2007, 04:37
  Screen goes black for half a second in Screen Virtuoso avi video stream.By 2prfm in forum Newbie / General discussionsReplies: 2Last Post: 6th Jul 2007, 12:16
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
