hi
I've captured some material as an avi dv file via my advc convertor to my PC and my client wants me to supply the material as a quicktime file so that they can edit material using final cut pro in good quality.
Can someone advise me if there's an economical program that will enable a decent conversion?
I do have tmpgenc 4 express but it appears to only convert to what it describes as 'a Quicktime (Mov) Output which it describes a compressed format used for example in digital camera functions'
cheers
Get Quicktime Pro (cheap - US$29 if I recall correctly) and convert the file to a Mac compliant .DV file. It is just a Mac friendly repackage of your DV data, so re-encoding, no quality loss, and FCP should have no trouble with it.
Read my blog here.
How to play Quicktime with PNG codec on my videoplayer (not quicktime)
By Henkie in forum Software PlayingReplies: 0Last Post: 11th Nov 2011, 03:50 -
Quicktime Pro 7
By JBird in forum Newbie / General discussionsReplies: 4Last Post: 11th Aug 2010, 10:15 -
Best import to Quicktime...
By bsuska in forum Video ConversionReplies: 26Last Post: 23rd Sep 2009, 15:03 -
Quicktime
By skipowder1 in forum ffmpegX general discussionReplies: 1Last Post: 19th Jul 2009, 17:12 -
Quicktime 7.4
By matthewjohn23 in forum Video Streaming DownloadingReplies: 1Last Post: 4th Apr 2008, 15:42
