I having been using the DVDFab Decrypter - DVD Shrink - ImgBurn method to back up my DVDs to single layer DVD-R discs for a long time without any problems. But when I try to make DVD+R DL backups there are always glitches when playing back the movie. Do you have to use another method for dual layer encoding and burning?
				Results 1 to 9 of 9
	I don't understand where DVD Shrink fits into this process Read my blog here.
	Originally Posted by guns1ingerOriginally Posted by xoADAMox
	Yes. Remove DVD Shrink from your equation. It is completely unnecessary when dealing with DL burns.Originally Posted by xoADAMox
 Your playback problem could be several things.
 1) Try burning at lower speeds.
 2) Your DVD player simply may not do well with DL media. It happens. Some DVD players have been known to not play DL media at all.
 3) You are using DVD Shrink and it's messing stuff up like maybe changing the layer break. Don't use it in any part of your DL ripping and burning process.
	If you don't have a full version of DVDfab Decrypter then DVD Shrink is useful for d/l discs to replace unwanted warnings etc... with static images. You just have to make sure all audio and subtitles are selected and the compression is set to 100% (no compression) but I don't use it for anything else in the process. There's not much to do but then I can't do much anyway.
  Backing Up media filesBy AndreL in forum MediaReplies: 1Last Post: 11th May 2011, 04:54
  Problem backing up Blu-Ray using BD Rebuilder with milOtis methodBy TJMac44 in forum Blu-ray RippingReplies: 15Last Post: 7th Mar 2011, 15:43
  best method to encode dvd'sBy codemaster in forum DVD RippingReplies: 8Last Post: 9th Feb 2011, 08:42
  Backing up video tapes with windows media centerBy macmaster in forum Newbie / General discussionsReplies: 2Last Post: 29th Dec 2009, 17:19
  Best method for backing up TV shows from DVDBy android6011 in forum Newbie / General discussionsReplies: 3Last Post: 23rd Jun 2009, 21:03
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
