i have nokia 5800xpress music mobile.screen resolution size 640x360.i can using free 3gp converter,ultra video converter finally srtightsoft super video converter.every converter uotput have audio delay.i like erightsoft super video converter.coz, its converts 640x 320 size nicely.but its also have audio delay.i can use the following configuration in super video converter,
i have nokia 5800xpress music mobile.i can use to convert videos to my mobile,using erightsoft super video converter.its converts 640x360 resolution nicely.but audio delayed.how to i fix this?
i dont need other converter.i want to know correct configuration to my nokia 5800 on erightsoft super video converter.my default configuration as follows,
Output File: mp4
Output Video Codec: mpeg-4
Output Audio Codec: AAC LC
Video General Options: Both unchecked
Video Scale Size: 640×360
Video Aspect: 16:9
Video Frame/Sec: 25
Video Bitrate: 816
Video Other Options: “High Quality” and “48k Audio” are checked
Audio General Options: Both unchecked
Audio Sampling Frequency: 44100
Audio Channels: 2
Audio Bitrate: 112
DVD Language Select: defaul
any changes to avoid audio delayed?plz help me?
if any configuration changes avoid audio delay?plz guid me
I also have a Nokia 5800 and naturally want to use the best converter for this beautifull device (plays videos in 640x360 resolution on a 3.2 inch screen). I've tried a buch of free software for video conversion to MP4 format (not only for Nokia 5800) and below are my findings.
* Super - I don't use it, because it is unstable on my system. Sometimes I couldn't even close the application.
What a crap.
* Mediacoder - works fine, allows a good amount of controls.
The results are also good. Score 7/10.
* Format Factory - this little application works surprisingly well for me. There is even a preset for Nokia 5800. Easy to use, quite versatile and good conversion results. Score 8/10.
* Xvid4PSP - Does the job as well, but requires some experimenting to find the best presets. A good all round application. Score 9/10.
* Handbrake - I love the interface. 8) Not so versatile in controls. Crashes when I try to convert MKV to MP4 with AAC audio. Can't inspect visually the cropping effect before the encoding. Seems a bit slow than the other applications. Quality is good. Score 8/10.
* Any Video Converter Free - for beginners only.
I'd like to see more settings here. Score 6/10.
* Avidemux - I love it.
Does much more than you would expect. Score 9/10.
* WinFF - Installed it, looked at the settings and uninstalled it. Useless. Score 1/10.
* Xmedia Recode - Did some decent conversions, but there was no love. Score 7/10.
* Fair Use Wizard - didn't try this extensively, since it was limted to converting DVDs (with a requirement to make ISOs first).
* Free Zune Video Converter - Simple and effective. Not that versatile. Score 7/10.
Hope this helps.
Hi
Thank you for your list of converters.
My wife has a Nokia 5800 and asked me to put some movies on for her. I said no problem my dear... The time is now 0215 and I am beginning to be very frustrated about all this. I have been able to encode a couple of movies but most of them either lack sound or picture. Sometimes the sound is played with half or less the speed. Is is really this hard to encode movies?? I have only tried to encode samples of HD *.mkv files (720p)
You mention Avidemux as a good piece of software but it lack batch processing.. My plan was to drag and drop all my 100 movie files into a converter and lean back.. Too easy??? -
It was a while ago, that I've posted this...
To make easy batch video conversion for 5800XM, I'd recommend Format Factory (download the latest version, there is a preset for 5800XM) or Any Video Converter Free (use the settings from Format Factory). I would also try Handbrake, but I often had issues in mkv to mp4 encoding.
The recommended conversion settings should be:
video encode: MPEG4 (DivX)
file format: mp4
resolution: 640x360
aspect ratio: 16:9
video bitrate: 768kbps
framerate: 25fps
audio encode: aac
audio bitrate: 96kbps
Two questions: Best free video converter & Best free muxing tool?
By milOtis in forum Video ConversionReplies: 7Last Post: 9th Jul 2011, 18:40 -
Video Converter For Nokia N8
By skorpinok in forum Video ConversionReplies: 1Last Post: 4th Jun 2011, 09:32 -
How to encode Videos for Nokia 5800/5230 (Symbian 60 5th) ?
By ahollmann in forum ffmpegX general discussionReplies: 8Last Post: 18th Apr 2010, 11:46 -
Converter for Nokia 5800XM
By Argonisius in forum Video ConversionReplies: 2Last Post: 14th Jan 2010, 01:56
