I just bought a Mac Book. I want to capture live video from my canon GL2 camera using Imovie. I know that it automatically saves it as a .dv file. I then want to move the file to an external HD and then open the external HD with my PC (Vista) and use Studio Pinnacle 11. However... Studio wont recognize .dv files! So what can I do?? I will have sometimes 5 hours of video to maybe 35 hours of video when I capture! Is there software for mac that I can capture it directly as an .avi? Then my PC would easily be able to open it! I really dont want to convert .dv files becuase I am sure that will take a long time and I might lose quality! Quality is a must for me as well! Please help me out!!! Tonight was the first time I have even used my MAC!
Thanks,
Blaine
You can capture on the PC and convert the file on the Mac. WinDV is a good PC capture program.
iMovie8 will open a DV-AVI but won't export to DV-AVI. Quicktime Pro ($30) on the Mac will convert .dv to DV-AVI. There is no loss.
The Mac can read and write to a FAT32 formatted hard drive partition but can only read from NTFS format.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
Thanks, I am trying to use my Mac book to do the capturing. How long will it take Quicktime Pro to convert the .dv to a .avi file for a 1 hour long clip?
Use a MAC to capture...Use a PC to edit? Help!!!
By blainedepue in forum Video Streaming DownloadingReplies: 1Last Post: 27th May 2009, 03:43 -
How can I transfer CCD V5000 Hi8 Analog Video to digital/MAC to edit?
By thebird in forum Newbie / General discussionsReplies: 0Last Post: 15th Apr 2009, 05:36 -
Capture DV with PC/Edit on Mac with FCP????
By mkoplin in forum Capturing and VCRReplies: 1Last Post: 29th Dec 2008, 20:33 -
best format to edit on a mac
By devdev in forum Video ConversionReplies: 6Last Post: 16th Jan 2008, 00:07 -
DV capture on Mac
By thuriel in forum MacReplies: 11Last Post: 18th May 2007, 09:02
