I have two avi files that I need to join, and Virtualdub does not accept them.
Avidemux was suggested on this forum to do that, on a past topic, but I can't quite understand how to do that. I could load the file and run it, but I wonder how to go on.
Can anyone name the steps for a join there or tell me where I can get some info about it?
Results 1 to 14 of 14
Left Column: HOW TO - Edit
http://www.dvd-guides.com/content/view/14/59/Google is your Friend -
That is a guide to use with VirtualDub. But I said I can't load my files in VirtualDub.Originally Posted by Krispy Kritter
What I want to know is how to do that with Avidemux.
Does anyone know how to join files with Avisynth? -
OK. Worked up fine and the files are joined.
Now how do I demux the audio from the avi video file?
I would like to convert this file using avisynth, but when I load it as AVISource in AvsP I get the error:
"No compatible ACM codec to decode 0x2000 audio stream to PCM".
So I thought perhaps I can get it to work if I separate video from audio.
Or should I use a different loader? -
AC3 ACM Decompressor
AC3Filter
I can't remember which one of the two you need, but it is one of them.If in doubt, Google it. -
Sorry, I had to go see about a girl
I apologize for linking the wrong guide. My point, however, is that you can search for guides by the type of work or by the tools used. The HOW TO section can answer all of your basic questions.
...As pointed out above, I'd get the AC3 ACM Decompressor linked above and see if VDub still complains. That should do the trick.
Sorry, I had to go see about a girl -
I did get AC3 ACM and put the plug in in VD. VD still complained and froze when I tried to run it. VDM did not complain and showed the audio stream, but did not show any video. In any case, if you demux the streams with VDM you get a wav track, right? Avidemux gave me the right 5.1 AC3 track. At least for this job it proved better.Originally Posted by midnightsun
BTW. I ended up using directshowsource to load the avi file and it worked fine.
HCenc is now finishing converting. It took about 7 hours to do it, instead of the usual 3-4 hours it does. Probably because I used LSFmod to improve resolution.
Would I do it in less time if I take advantage of my 2 cores with MT avisynth? Would it work for that filter?
joining avi files
By dugen in forum MacReplies: 1Last Post: 11th Jun 2011, 13:47 -
Joining AVI Files
By wulf109 in forum Video ConversionReplies: 4Last Post: 4th Nov 2010, 15:17 -
Joining AVI files
By nycdude in forum EditingReplies: 6Last Post: 21st May 2009, 00:03 -
Joining avi files?
By tofuguy in forum EditingReplies: 4Last Post: 7th Oct 2008, 03:30 -
Joining avi files?
By t_jay17 in forum EditingReplies: 5Last Post: 18th Dec 2007, 13:22
