Hi,
If I burn a VCD with a menu using Nero 5.5, WinDVD (or another DVD Player I tested) does not detect it and cannot play it. I tried with no menu and everything is Ok.
By searching for an answer in your forum, I found a few other persons having the same problem but there was no answer.
May it be a problem of compliancy with my burner or the CD-ROM I use ?
Thanks for your help,
POB
i get exactly the same problem let me know if you get an answer to this elusive Q
Eh!.......don't know why it's doing that, it worked perfectly well on my system !!!!!!!!!!!!!!! -
Nero 5.5 menus are not authored correctly. They don't work on most software DVD players and even some hardware ones.
If you want menus, I suggest trying VCDImager, VCD Toolkit or VideoPack 4 or one of the newer ones that are out.
Regards.Michael Tam
w: Morsels of Evidence
Can I use Nero to join DVD with menu?
By csh in forum EditingReplies: 3Last Post: 12th Nov 2007, 10:58 -
Need input with convertx2dvd and nero 7's menu builder
By MidnightMike in forum Authoring (DVD)Replies: 4Last Post: 9th Nov 2007, 13:48 -
Menu Music with Nero Vision
By Smudge249 in forum Authoring (DVD)Replies: 2Last Post: 7th Nov 2007, 05:09 -
Nero Vision 5 menu audio help?
By sls-sls in forum Authoring (DVD)Replies: 1Last Post: 31st Oct 2007, 12:26 -
Can chapters created in Nero 6 show up in menu?
By wayney in forum Authoring (DVD)Replies: 2Last Post: 15th Jun 2007, 11:46
