Hey everyone.
I am using photoshop v.9 and adobe premiere 2.0.
I had save a psd in photoshop and imported it into adobe premiere. I made a few chance to the PSD and save it. It automatically updated in premiere and screws some layers up. I did a lot of motion work so starting over is just so stressful.
Is there anyway update the layers with in Premiere? I have tried replace the layers with new PSD files and nothing is happening. Please help! I'm really scared i that i will have to do this all over
Thanks in advanced.
Results 1 to 9 of 9
What do you mean "screws some layers up" ? Can you be more specific ?
If you didn't want the dynamic update, just save a renamed file or work on a copy
The integration between Adobe products has significantly improved in CS4 -
The first time i imported the PSD into premiere everything was fine. After that I had worked on a few things in the photoshop and save it,it was then that all the layer in premiere had switched around.
I tied to import each layer 1 by 1 into preimere hoping it would ask me to replace the layers and it didnt, nothing changed
hope this clears it up... -
right click on the old asset in the project panel, select replace footage, browse to the new psd and select it
ok, in older versions I think the work around is right click, make offline (don't delete files) , then right click the "offline file" , select "link media", select new psd
wow okay well i don't feel so stupid because I actually tried that exact method and it didn't work : ( I'm going to try it again..
Are you sure? Is your version Premiere Pro 2?
I just checked on an older PC that has Premiere Pro 2 installed and it swapped assets fine...
What kind of things did you alter in the psd ? Certain things won't necessarily retain their relationships to other assets in the main project sequence. Or are you saying it won't swap at all (i.e. nothing changes?) -
yeah it wont swap at all. I ended up recreating it layer by layer effect by effect took a log time but i had a deadline to. Hopefully i dont run into this problem again
Adobe After Effects, how do you view all layers at once??
By Devilsadvocate in forum EditingReplies: 5Last Post: 2nd Mar 2012, 12:58 -
Adobe Reader needs updating every week or so?
By edong in forum ComputerReplies: 2Last Post: 25th Mar 2011, 20:43 -
Sticky layers in Premiere
By mikal2 in forum EditingReplies: 1Last Post: 22nd Mar 2009, 19:41 -
Adobe Premiere 1.5: Adobe Media Encoder: Frame size and scaling?
By vid83 in forum EditingReplies: 2Last Post: 30th Nov 2008, 04:17 -
Updating Adobe Premiere Cs3 h264 codec possible??
By craig198 in forum Newbie / General discussionsReplies: 5Last Post: 17th Oct 2008, 23:02
