Anyone know how to extract subtitles stored in an AVI? I have an AVI that has subtitles that appear to be stored inside the AVI file, similar to what you would see in an OGM or MKV file.
When looking at the file list in Mplayer, only the audio and video IDs are seen and the subs do not show up in the list nor do they play.
Also, when I open the file in VirtualDubMod, select the Stream list, I don't see any subs in there either.
However, when I play the AVI file in Media Player, FFDShow and DirectVobSub popup in the Systems Tray and the Subs play.
I need to put this AVI file on DVD, is there a way to extract the Subtitles from the AVI. This is the first time I have seen an AVI file like this and didnt even know it could be done, even though I guess AVI is a container as well. I tried using Avisynth with the DirectShow Filter but the Subs didnt show there either.
Again, I need to put this AVI file on DVD, so the best solution would be to somehow burn them into AVI file when encoding using an AVISynth function to somehow select the Subtitle, but if there is an extraction program, that would be fine too.
Below is the MediaInfo, as you can see, it says that there is an SSA file inside, but I have no idea how to extract it.
Code:General Complete name : C:\temp\Projects\DBZ\dbz.avi Format : AVI Format/Info : Audio Video Interleave File size : 233 MiB Duration : 20mn 41s Overall bit rate : 1 576 Kbps Video Format : MPEG-4 Visual Format profile : Simple@L3 Format settings, BVOP : Yes Format settings, QPel : No Format settings, GMC : No warppoints Format settings, Matrix : Default (H.263) Codec ID : XVID Codec ID/Hint : XviD Duration : 20mn 41s Bit rate : 1 430 Kbps Width : 640 pixels Height : 480 pixels Display aspect ratio : 4/3 Frame rate : 23.976 fps Resolution : 24 bits Colorimetry : 4:2:0 Scan type : Progressive Bits/(Pixel*Frame) : 0.194 Stream size : 212 MiB (91%) Writing library : XviD 0.0.09 (UTC 2003-03-25) Audio Format : MPEG Audio Format version : Version 1 Format profile : Layer 3 Codec ID : 55 Codec ID/Hint : MP3 Duration : 20mn 41s Bit rate mode : Variable Bit rate : 137 Kbps Nominal bit rate : 128 Kbps Channel(s) : 2 channels Sampling rate : 48.0 KHz Resolution : 16 bits Stream size : 20.3 MiB (9%) Alignment : Aligned on interleaves Interleave, duration : 24 ms (0.58 video frame) Interleave, preload duration : 409 ms Writing library : LAME3.92 Encoding settings : ABR Text Format : SSA Stream size : 11.8 KiB (0%)
Midzuki, I downloaded that an hour ago but I couldn't figure out how to extract. The "Mux" implies that you are muxing and not demuxing.Originally Posted by Midzuki
I will retry to use the software. Also, do you know if this tool has a CLI? -
Midzuki, I figured out how to extract them manually.
Any idea about using a CLI, there are quite a bit of files like this?
How Can I Remove the Subtitles from a .VOB File and a .AVI File?
By channelz28 in forum Newbie / General discussionsReplies: 3Last Post: 21st Nov 2011, 19:45 -
Please, advice batch converter what support .mkv with few subtitles inside.
By Nikolay_PI in forum Video ConversionReplies: 2Last Post: 24th Aug 2010, 11:56 -
Can't play avi files stored on WHS with MCX hosted by Vista x64 MC PC
By satwar in forum Media Center PC / MediaCentersReplies: 0Last Post: 30th May 2009, 18:45 -
Display subtitles inside a divx file
By renzord in forum SubtitleReplies: 8Last Post: 2nd Nov 2008, 12:46 -
Media Player Classic and subtitles inside TS files
By boulder in forum SubtitleReplies: 2Last Post: 19th Sep 2008, 16:55
