I have DTS 5.1 movie track. I want to convert it into AAC 5.1 to sound exactly as DTS source track.
SO what bit rate I shall choose and what tools are the best for this work?
I would use XVID4PSP which has an AUDIO only option (or can do video and audio). It can do 5.1 DTS to 5.1 AAC or it can do 5.1 DTS to 5.1 AC-3
other options: eac3to, foobar2000 with dts plugin, megui, behappy
This is a lossy conversion, so the higher the bitrate, the better the quality. Experiment with different bitrates, your ears or audio equimpent may only need 320kbps (for example), but others may need more or less
What's the difference betwen AAC, AC3, and DTS audio's for movies?
By Eagleman in forum AudioReplies: 3Last Post: 29th Aug 2011, 14:36 -
MeGUI audio encoding dts/ac3 to aac-mp4, keep getting errors
By runLoganrun in forum AudioReplies: 5Last Post: 29th Jul 2010, 18:15 -
DTS to AAC in MEgui
By kadyn67 in forum AudioReplies: 2Last Post: 22nd Jun 2010, 01:04 -
Problem with HD-DTS to AAC
By Z.Sath in forum AudioReplies: 2Last Post: 24th Apr 2009, 10:58 -
DTS to AAC
By bilbonvidia in forum Newbie / General discussionsReplies: 1Last Post: 18th Jan 2009, 18:24
