having issues to download certain files from rapidshare
some files no matter what cant be downloaded, as free user it says your ip is already downloading..bla bla...but
if i download another file all is OK...
anybody knows solution why is this happening and how to get over it?
anybody had similar issues why only certain files cause this problem?
thanks for any input and help
It sounds like you are behind a firewall that perhaps distributes traffic across several proxy servers. This is not an uncommon model for ISPs. Rapid-share sees the proxy server address as the downloading address. If multiple people who use your ISP are downloading form Rapid-share it will see these as the same IP address. As traffic cycles around the proxy servers, sometimes you hit one that is already being downloaded through, sometimes you don't.
The only way around this is to connect without using the proxy server if possible. Some ISPs will allow this, some won't. If you can do this, at least the only limitation will be downloads from your IP address, which you are in control of.Read my blog here.
As a free downloader (non-premium) you can only download one file at a time. After downloading that file, the amount of time you have to wait to download the next one is determined by how big that file was and how big the next file is. With small files, you may be able to start almost right away. Large files may make you wait for some time.... I have waited for 5 minutes up to an hour. If you have a lot of files you want to DL for free, use a downloader and let it do the work while you go have a life for a while.
Question how Rapidshare download manager works
By jimdagys in forum ComputerReplies: 2Last Post: 13th Mar 2010, 07:29 -
Alternatives to Rapidshare ?!
By Delta2 in forum ComputerReplies: 15Last Post: 3rd Dec 2009, 17:51 -
rapidshare download problem
By deejay.2001 in forum Off topicReplies: 0Last Post: 6th Aug 2008, 13:04 -
The unsolvable problem .. RAPIDSHARE
By ZaYoOoD in forum ComputerReplies: 9Last Post: 13th Apr 2008, 15:51 -
my rapidshare been block(closed)
By pcb in forum Newbie / General discussionsReplies: 4Last Post: 8th Apr 2008, 01:43
