I have been attempting all day to edit a MPg2-PS file. I am trying to do the following
1 - Crop some of the vertical line resolution (the file is 1280x1088 I want to make it to 1280x1080)
2 - delete a part of the beginning and the end
I have tried avidemux which hasn't worked, (audio won't sync which is a common issue, and filters won't work when cropping)
DGindex which doesn't allow me to Re-mux the file
MPG video wizard
TPGenc which is forcing to re-encode the file
Videoredo does everything I want but I can't crop the file
I do not want to compress the file at all
What program would you recommend I use to do the things I want
here is the
General
Complete name :testfile
Format : MPEG-PS
File size : 8.44 GiB
Duration : 2h 30mn
Overall bit rate : 8 052 Kbps
Video
Format : MPEG Video
Format version : Version 2
Format profile : Main@High
Format settings, Matrix : Default
Duration : 2h 29mn
Bit rate mode : Variable
Bit rate : 7 348 Kbps
Nominal bit rate : 65.0 Mbps
Width : 1 280 pixels
Height : 1 088 pixels
Display aspect ratio : 16/9
Frame rate : 29.970 fps
Colorimetry : 4:2:0
Scan type : Interlaced
Scan order : Bottom Field First
Bits/(Pixel*Frame) : 0.176
Stream size : 7.70 GiB (91%)
Audio
Format : AC-3
Format/Info : Audio Coding 3
Duration : 2h 30mn
Bit rate mode : Constant
Bit rate : 384 Kbps
Channel(s) : 2 channels
Channel positions : L R
Sampling rate : 48.0 KHz
Video delay : -1s 819ms
Stream size : 412 MiB (5%)
interesting then what settings should I use to not have any real loss in quality
thanks -
1280x1088 is a new one for me. Where did you find that?
http://www.kiva.org/about -
when extracting files from my dvr , it added an additional 8 lines on the bottom. According to DGindex it warns me "your stream specifies a display height of 1088. This is sometimes an encoding mistake and the last 8 lines are garbage. Do you want to treat it as if it specified a height of 1080?"
and yea they are just 8 lines of grey line garbage at the bottom of the screen which is annoying to look at. So I want to take those lines out and cut the beginning and the end off without losing quality
Thanks again
Now that I think of it DGindex corrects the video problem but I can't find a program to Re-mux the video and audio stream back together after it corrects the 8 lines of garbage,
What program could I use to re-mux the file ? -
Try TMPGEnc MPEG Editor 2 (or even MPEG Video Wizard).Originally Posted by too2buff
mpeg2 ts file convert to mkv or mpeg2 ts......change only video bitrate...
By jrblack in forum Video ConversionReplies: 4Last Post: 24th Jan 2011, 18:45 -
Help :Editing mpeg2
By striker9 in forum Video ConversionReplies: 4Last Post: 7th Nov 2010, 10:05 -
convert hd pal mpeg2 file to hd ntsc mpeg2 file
By gearo in forum SVCD2DVD & VOB2MPGReplies: 8Last Post: 5th Jun 2008, 01:12 -
Editing mpeg2
By jkipp in forum Newbie / General discussionsReplies: 5Last Post: 7th Sep 2007, 12:38 -
Editing: MPEG2 vs DV AVI
By daamon in forum EditingReplies: 6Last Post: 5th Sep 2007, 11:35
