  1. Banned
    May 2006
    Downloaded a video File, that is in a .DAT Format
    Do I need to convert it to .avi or some other format to play the Video file.........Thanks.
    Apr 2004
    Miskatonic U
    VCD uses .dat files, amongst others, as part of the structure. You can extract the video to an mpg file with VCDEasy, if that is what it is. It is unusual to download just a dat file though.
    VLC should be able to play it as-is, to confirm that you actually have what you think you have
    Read my blog here.
    Aug 2002
    South Florida
    VCDgear also does a good job of converting to mpg.
    Apr 2004
    Miskatonic U
    VCDGear is the one I meant - thanks for that
    Read my blog here.
