i swapped out everything out of a case and put it in a different case and now the computer wont power on. i get the motherboard power led that is on but nothing happens when i hit the power button. I have the power button wires i think in the correct place. here is a diagram of it. Its page 3, section4. The power button switch is a blue and white wire and put them in the 2 pink pins on the diagram. i put the blue wire on the end pin. something else i should try.
http://usa.aopen.com/downloadfile.aspx?RecNo=7172&Model=712&Section=8&DL=yes
Results 1 to 13 of 13
Most likely the power/reset switches from the front panel are misconnected.
http://www.kiva.org/about -
nope power supply is the culprit. i put in another PS and it comes on. bad thing is that the working PS doesnt have a sata power connector. the old one trys to come on tho.
musta been one of those situations where the ps you had in the old case was in there for while and liked where it was at and its new home...it was dissatisfied lol...had an old fridge i cleaned one time...the bottom grill..all the dust it collected etc...next day it died lol
sorry about that....u should be able to get one for 50 bux or less...or maybe find an adapter for the one that worx...sata adapter -
i found an ide to serial sata power adapter off ebay for several dollars but i nned one now. wonder if best buy sells em?
Would be better to buy a new good quality psu that you can use in future mb.
This weekend is a good time to shop for power supplies and most other things.
I just scored a 45% discount on a Polk Center Speaker and a telescope accessory I've always wanted.Recommends: Kiva.org - Loans that change lives.
on the diagram it has 4 pins for the hdd led. Can the 2nd set of pins be used for a slave hdd? my master is the sata and i have a slave that uses ide.
The picture above lacks detail for the LEDs.
It should be described in the manual.Recommends: Kiva.org - Loans that change lives.
If you clicked on the op link it shows the manual and all details,the hdd led is used for both hdd,not sure why there is a second hdd led connection since the led is for the computer case.Originally Posted by edDVI think,therefore i am a hamster.
ok i got another problem now. bought a new PS and installed it. COmputer powers on and boots up. It goes the the XP boot screen and seems to be at the boot screen for the normal time but after it would normally go to the windows login/user selection screen but it doesnt make it there. Monitor shows not connected and it reboots. I booted to desktop in safe mode and did a system restore but that didnt help. any ideas?
Focus on the video driver, uninstall current and let Windows install a generic driver.
I would also Remove and Replace the video card, also check all cards to make sure they are completely seated into the expansion slot.
This case swap did not involve switching ANY parts other than the case, and now the PS, right?
computer power ghz ?
By luc13137 in forum EditingReplies: 6Last Post: 2nd Aug 2010, 23:08 -
How do I figure out what power supply my computer has?
By Bill in NH in forum Newbie / General discussionsReplies: 4Last Post: 26th Mar 2010, 01:15 -
Computer Won't Power On
By Sakuya in forum ComputerReplies: 8Last Post: 2nd Dec 2007, 02:24 -
Computer Monitor Won't Power Up
By StrengthFTW in forum Newbie / General discussionsReplies: 4Last Post: 24th Nov 2007, 12:08 -
Computer will power on but not boot
By surger1 in forum ComputerReplies: 18Last Post: 20th May 2007, 17:21
