Today, I tried opening Mozzila Firefox browser, but after only a few seconds it stops working and has to exit.
FLV player is the same, no matter how much I try to open an FLV file, it won't respond.
Although Internet Explorer and Windows Media related files still work
If you are wise enough to backup your Firefox profile with something like Mozbackup, you maybe able to restore Firefox.
Or do what I do to backup everything, including all add-ons and their settings
If using WinXP just copy the mozilla folder from the application data folder for the current profile and thats it, if your install screws up or you have to reinstall Windooze then reinstall FireFox and after running it the first time simply copy back that folder to the Application Data folder and all your settings are perfect again
Saved me aggrevation loads of times trying to remeber all the settings for various add-ons I use, like tab plus and the very handy adblock plus with the even better elements adblock addon
Can't open FLV with Avisynth
By Greensmurfet in forum Video ConversionReplies: 1Last Post: 21st Oct 2011, 19:00 -
Firefox - finding out last several windows/tabs that were open?
By sldvd in forum ComputerReplies: 1Last Post: 7th Oct 2011, 20:25 -
can't open flv in VirtualDub
By shun in forum Video ConversionReplies: 3Last Post: 26th Jul 2010, 19:10 -
Can I get an embedded flv to play both in firefox and internet explorer?
By grampazero in forum Newbie / General discussionsReplies: 1Last Post: 1st Mar 2010, 08:27 -
Can most computers usually open an flv file?
By grampazero in forum Newbie / General discussionsReplies: 2Last Post: 20th Feb 2010, 03:08
