I am using the following to add subtitles from an ssa file to an avi while encoding it to VCD.
- virtual dub 148
- tmpgenc 2.02
The problem is that it appears that tmpgenc crashes some where near the end of the filmclip. The frameserver remains open and apparently operational.
Has anyone else experienced this problem and is there a solution?
Here is some more detail on the problem. The movie that I am subtitling cam in two pieces. The second hafl worked perfectly with virtualdub serving frames to tmpgenc with no error. When the film was finished, tmpgenc remained open and waited for me to close it down.
The first half of the movie consistently bombs out at the very end, with seconds of the completion of the segment. Is it possible that the file is not properly terminated and if so, what can I do about it? -
Have you tried to do a File Save with VirtualDub? You may want to try that, save the AVI to a different name, open it up with VirtualDub again and try FreameServe. Not sure if that will work, but it will save to the Virtual AVI format.
Bud
iDVD bombs out during the middle of encoding
By Nilfennasion in forum MacReplies: 6Last Post: 9th Aug 2011, 11:52 -
Can't Frameserve to Tmpgenc
By BonnieW88 in forum Video ConversionReplies: 1Last Post: 30th Aug 2009, 23:40 -
Frameserve from virtualdub to HC
By SatStorm in forum Video ConversionReplies: 2Last Post: 12th Jun 2009, 06:24 -
How to frameserve this resizing algorithm to TMPGEnc?
By DRP in forum Video ConversionReplies: 3Last Post: 4th Jan 2008, 22:19 -
Frameserve from VirtualDubMod to TMPGEnc
By pchan in forum DVD RippingReplies: 1Last Post: 25th Aug 2007, 08:13
