I transfered (Captured) a DV AVI file from my camera to my PC using windows movie maker. I wanted to keep the orginal AVI format file so I has a "Orginal quality" like what's on the tape copy. When I play it back in Window Media Player I have combing from the interlacing of moving objects not being alligned. If I pay in in Windows Movie Maker is looks fine. If I convert the file when I capture it to NTSC I alssee no problems. Why don't the orgianl AVI files get interlaced correctly so they look like the lower res NTSC? Do I need to add some filter or codec setting? Thanks I'm new to DVI conversion world.![]()
If you want to keep it in original quality it will always be interlaced. If you want to play it just on computers then make a new deinterlaced copy or use video players that can deinterlace like vlc media player.
And I'm moving you to our dv section. -
Can Windows media player be setup to perform the proper deinterlacing? If I wanted to create a de-interlaced AVI file would that be possible or are AVI's always interlaced?
I be outputting to HD displays like projectors and TVs. But I do use Windows Media player a lot. Can it be cofigured correctly?
As another thought should I just convert them to another format that will not show much degredation and just delete the AVI's?
Annoying "combing" affect on AVI files
By djdust in forum Newbie / General discussionsReplies: 1Last Post: 27th Feb 2011, 19:01 -
combing avi's
By halekon in forum EditingReplies: 4Last Post: 2nd Aug 2009, 09:22 -
'Combing' effect when playing VOB files with Media Player Classic
By djdust in forum Software PlayingReplies: 1Last Post: 16th Oct 2008, 21:23 -
Premiere AVI to Encore to DVD - combing/horizontal lines on TV
By spicediver10191 in forum Video ConversionReplies: 0Last Post: 14th Nov 2007, 08:18 -
Anyone know exactly how this works? And if files can be transfered to.it
By betamaxman in forum LinuxReplies: 4Last Post: 10th Jul 2007, 23:45
