    Sep 2006
    Is there a good free slideshow creator out there with lots of transitions and capability to add music
  2. Member yoda313's Avatar
    Jun 2004
    The Animus
    windows movie maker is one. However it is XP or higher only. Also the default output is wmv. But you should be able to set the output to dv-avi so it can be converted to other formats more readily.
    There are plenty of other choices to look into here:
    https://www.videohelp.com/tools
    I don't know how many are free but most have trial versions available to test before buying.
  3. You can try DVD SlideshowGUI . You can export to other format like .avs script instead of DVD-Video
