I need some help from the PC gurus here. I have just recently completed a new PC build. Specs are below
Processor: AMD Phenom II X4 955 (Black Edition)
MB: GIGABYTE GA-MA790XT-UD4P AM3
Memory: OCZ Gold 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (using only 2 sticks for 4GB)
OS drive: 300GB Raptor (10,000 rpm)
Video Card: MSI R4350-D512Hv2 Radeon HD 4350 512MB (not used for gaming)
OS: MS Vista Ultimate 32-bit
I was curious to measure the performance increase vs my previous system (AMD Athlon X2 4400+) by running a simple encode using AutoGK. The test clip was a 2:35 minute DV-avi (720x480). On my previous system this clip required 4min 33sec to encode ( 23.29 fps). On my new setup, the identical clip required 7 min, 41sec (14.95 fps) to encode using identical settings. This is a complete shock to me.
The new machine is my first experience with MS Vista, but I have attempted to optimize it per tweakhound's vista guide. The task manager shows that the system is not particularly taxed during the encode (CPU hovers around 70%, Mem usage at 1.18GB). Are there settings that need to be enabled in Vista or the Bios that will enhance performance? Any other thoughts?
Thanks.
- Smells_Like_Feet
Results 1 to 17 of 17
Just a thought, but try changing the power options in the control panel to "high performance", see if that does anything...
mh2360,
Thank you so much. After following your suggestion, the encode time dropped to 2:12 (53.92 fps). I had no idea that the power setting could impact it so much. Needless to say, I am satisfied with this result. Thanks again for the help, and the quick reply.
- Smells_Like_Feet -
Most software fails to use all the cores -- it's that simple.
Yes, it's confusing as to why Microsoft would use a default power setting that could impede modern PCs so much. Makes you wonder how many Vista users there are who are oblivious to the fact that their systems are not running as fast as they could.Originally Posted by Smells_Like_Feet
My guess is its part of their "green" initiative. To make them look more ecofriendly I guess..... blah blah...Originally Posted by mh2360
Thanks for the tip. I'm running a dual core amd x2 2.7ghz on Vista Premium 32bit. I have just changed my power setting to power performance or whatever. I'd be interested to see if that gives a power boost on the encode times. In fact I have a standard def encode I have that I can test it on.....
FYI not that I"m overly eco minded but would it make sense to throttle back to balanced if all I am using the pc for is downloading? I mean I'd only need full power for encoding jobs not for downloads.....Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
Besides using more than one core, some apps fail to scale well at all.Originally Posted by lordsmurf
Which is why, in many cases, an e8400 (3.0x2) is faster than a q6600 (2.4x4)Linux _is_ user-friendly. It is not ignorant-friendly and idiot-friendly. -
Smells_Like_Feet you should get a 64 bit version of vista. Since that 32bit version is only using like 3.5gb of your 6gb. With a 64 bit version you could use all the memory.
If he's just encoding, extra memory won't make any difference and using V64 may cause other problems.Originally Posted by davidsama
Most all laptops are set at default 'power saving' mode to increase battery life. I've disabled all that on my laptop as it runs on a power brick anyway. Don't know why they would want to do it with a desktop PC unless it is part of the 'Green' trend.
Most newer motherboard software and BIOS can ramp up the PC performance when needed, and when idle, slow it down, so there's no reason to use power saving settings within the OS, IMO. Let the MB software/firmware do it if you need to be 'Green' and you can still have your performance.
Some of my newer MBs can control the CPU voltage, CPU multiplier and fan speeds for idle use, then run the system at full power for a encode or other CPU intensive operation, all automatically. -
I have a gigabyte desktop board that did this. Frankly it's down right annoying! You have to sit there and listen to the fans speed up, down, up, down, up, down. Damn thing used to shut the NIC off as well. This caused the DHCP address to be dropped, then a delay to poll for a new one ..... These green PCs have a ways to go. Thankfully, I could turn all that crap off in the BIOS.Originally Posted by redwudz
Seriously, how much power savings is something like this actually going to give you? $2.00 on the year
People buy power hungry PCs because they need the power. Then again, some people aren't that smart and believe a quad core with 8gigs ram will make internet exploder load myspace faster
So then if I buy a new quad core and 8gigs ram I won't be able to encode a bluray movie to mkv in less than half an hour???? Man what a rip off!!!Originally Posted by disturbed1
So it's safe to assume that there are hundreds of thousands of Vista machines that will never run at full speed?
Oops. -
don't say "never" just highly unlikely....Originally Posted by Constant Gardener
My first quad core is a complete disappointment, speed-wise, for these reasons. I should have stuck with a dual core.Originally Posted by disturbed1
My dual systems work better in many cases, and even the single-cores in other cases.
I was having the same issue and i noticed there was no available memory. Somehow i remembering reading about superfetch a long time ago before i had a Vista PC. I did a search and found this link and superfetch has since been disabled and i'm happier with my pc performance.
from that link...Originally Posted by sikoone
Bah ...There's no hard evidence that enabling or disabling this service will increase performance in general, but if you open and close applications often you should definitely leave it alone. You will have to test your configuration to know for sure.
I'll give it a try, but that one machine only has about 4 programs installed beyond the OS -- it's an encoding box, nothing more.Want my help? Ask here! (not via PM!)
I think Vista was loading the programs i wanted to use into memory which was getting on my nerves. I was doing something really simple like joining 2 avis with Avidemux and a quad-core 8200 was taking twice as long as a dual core Amd 4400. After disabling superfetch things noticeably sped up.Originally Posted by lordsmurf
How to significantly reduce size of an HD video with nearly same quality?
By oedipust in forum Newbie / General discussionsReplies: 47Last Post: 22nd Feb 2014, 20:54 -
How to Be Sure It Will Be Possible to Revert to Previous OS Boot?
By jeanpave in forum ComputerReplies: 4Last Post: 1st Nov 2011, 18:41 -
Automatic jump to the next VTS from the previous
By src2206 in forum Authoring (DVD)Replies: 4Last Post: 28th Sep 2011, 05:32 -
VLC: opening at previous size?
By terrypin in forum Newbie / General discussionsReplies: 2Last Post: 7th Sep 2011, 01:45 -
Previous Versions of tsMuxeR
By DirectorSG in forum MacReplies: 2Last Post: 18th Sep 2010, 05:44
