What happened to the Virtualdub guides, on DVD to Avi, and DVD to Divx, VOB to Avi, and etc? Seems like some of the guides aren't listed under the Virtualdub app. page. When I do a search on theses types of conversion, there isn't a listing using Virtualdub.
Has everyone given up on this app? Is there a better way of converting these files?
Yes, use autogk or handbrake. Virtualdub is no dvd to avi converter.
Yes I know, but its a tool use in part for doing those types of conversions. They were there before, but now gone.Originally Posted by Baldrick
Virtualdub works fine for me using MPEG2 plugin.
Save DVD to PC as single VOB.
Open VOB in Virtualdub.
Demux 5.1 AC3 and add to Virtualdub using Audio > Audio from other file (you'll need the AC3 plugin for this). Choose Direct Stream Copy for audio.
Select compression of choice for video and save.
You can also use DGIndex to create an AVS file to open in Virtualdub. Here is a guide...
http://neuron2.net/dgmpgdec/QuickStart.html
EDIT: Here is the page you were looking for, I think. Most of these are old guides though and don't take advantage of the plugins and features of the new versions of Virtualdub.
https://www.videohelp.com/guides?tools=2&&archive=%25 -
And don't forget search for guides virtualdubmod and virtualdub-mpeg2. They had mpeg2 support first.
https://www.videohelp.com/guides?searchtext=&tools=332&madeby=&formatconversionselect=&...or+List+Guides
https://www.videohelp.com/guides?searchtext=&tools=72&madeby=&formatconversionselect=&h...or+List+Guides
But I stilL say it's not any dvd to avi converter...just a vob/mpeg2 to avi converter.
Wasn't there a way for Virtual Dub to capture AVI frames and send them to TMPGEnc as a MPEG?
There are no problems - only chances to excel.
-- Unknown -
It's called frameserving...
https://www.videohelp.com/oldguides/virtualdubframeserve
Fit2Disc Guides
By montgal in forum Newbie / General discussionsReplies: 0Last Post: 28th Dec 2009, 12:18 -
Questing about filtering with one of your guides
By Oni87 in forum Newbie / General discussionsReplies: 6Last Post: 21st Oct 2008, 17:26 -
Guides needed asap
By demonwarrior in forum Newbie / General discussionsReplies: 3Last Post: 12th Sep 2007, 07:35 -
FAVC guides?
By php111 in forum User guidesReplies: 64Last Post: 25th Aug 2007, 10:53 -
question about one of the guides
By php111 in forum Off topicReplies: 1Last Post: 8th Aug 2007, 10:31
