hi,
Im wondering, say you have a vid file 1 gig
and you want to just get the best bits out of it and
say reduce it to 80 meg.
Is there any way of doing that ?
On the audio side... its easy to put audio files into
audacity and edit the files down
why should it be so difficult with video ?
Results 1 to 14 of 14
THe file size doesn't say anything. How long is the clip?
You can use for example handbrake and convert to avi xvid or mp4 h264, under the video tab set the video size to 80 mb and convert and see how it looks like.
Or do you want to edit it? Windows Movie Maker. -
No.
I would guess 25 mins, 30 mins long
I have vids of various sizes but often theres about
10 % in there that I may wish to keep
but how to get that 10% out... there's the rub.
We download and play these files but we have no
control over them, we can t get at them
I suppose its video editing software that Im after
given the right equipment I could become the next
Alex Jones. -
Absolutely there is. The easiest way to do it depends on what file type you have now, and/or what file type you';re happy for the end result to be.Originally Posted by moonshadow
Over here on the left <<<=== under the "How To" heading is the word "edit" - it is likely to have some good info for you.If in doubt, Google it. -
thanks, I ve benn pointed in the direction of
virtual dub before and Ive got it installed,
but so often it does nt support the particular file
But then what are these files ? I just had a look
in properties of one and it said
.. file type.... BS player ! -
install the latest k lite codec pack and there is a good chance it will work in vdub and if not, use avisynth +directshowsourceOriginally Posted by moonshadow*** DIGITIZING VHS / ANALOG VIDEOS SINCE 2001**** GEAR: JVC HR-S7700MS, TOSHIBA V733EF AND MORE
You need the virtualdub-mpeg2 version to open MPEG-2 video.Originally Posted by moonshadowIf in doubt, Google it.
You could also use the newer VirtualDub versions and install the MPEG plugin. It's shown on the VD toolpage to the left <<<<<
Or try VirtualDub Mod as it accepts MPEG format videos. But VD outputs as a AVI type file, so you need to be aware of that. VD also had hundreds of filters available, so that's a big plus for it.
And this doesn't seem to have anything to do with Video Streaming. Moving you to our Video Conversion Forum.
And welcome to our forums.
Help Recovering a 29 gig AVI
By ReiverDemon in forum RestorationReplies: 11Last Post: 13th Dec 2009, 20:52 -
25 gig BluRay to BD-R?
By Mark_Venture in forum Blu-ray RippingReplies: 3Last Post: 6th Sep 2009, 07:56 -
12.5 Gig Panasonic DV file
By rayf01 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 15Last Post: 17th Jul 2008, 09:08 -
How many 4.7 Gig DVDs may fit into 500 gig HDD?
By Bronx in forum ComputerReplies: 11Last Post: 24th Apr 2008, 09:40 -
Philips DVP5960 and 1.4 gig avi
By dude112 in forum DVD & Blu-ray PlayersReplies: 3Last Post: 1st Dec 2007, 14:42
