I have the Encore ENLTV-FM card , I know that is a cheap card but for what I want it does its job, I mean just to transfer my VHS to DVD. I’m not looking for super quality just to pass my old vhs to dvd.
I can capture mpeg directly ( with the software included ) and I’m quite pleased with the output but my only problem is that I can’t crop the video while I’m capturing, you know to remove the borders of the vhs frame. Something I can do when I capture avi with Virtualdub. But I as said I wanna do it directly to mpeg.
My question is, is there a way I can capture mpeg with the right cropping at the same time whether using the same software, a hacked software or any other software or trick?
Any help will be highly appreciated, thanks in advance, Joe.
Until someone can provide a direct capture solution with settings, if they exist, I would suggest in the interim going the re-encoding route with a better capture method instead.
To crop with your existing setup you'd need to re-encode MPEG-2 -> MPEG-2, which would indeed be quite lossy.
I see you can capture to AVI. Can you access the VFW library?
Instead, use something like a lossless format, or DV-AVI, for your capturing. The files will be bigger, but that will be only temporary as you will want to re-encode to MPEG-2 anyway. And your results will be better.
It's not a direct solution, but at least this way you can do it with better captures and higher quality retentions (even if wasn't only just to crop).I hate VHS. I always did. -
Thanks puzzler for your answer, it was just out of laziness. I know the avi way it's the right thing to do.
Question about capturing Doctor Who VHS tapes
By fatcharlie in forum Capturing and VCRReplies: 30Last Post: 3rd Apr 2011, 23:42 -
Question/Opinion: Capturing from VHS to digital, then to DVD
By SupaDupaMonkey in forum Capturing and VCRReplies: 12Last Post: 11th Jun 2009, 16:28 -
Capturing DV VHS deinterlace question
By bgmagic in forum Video ConversionReplies: 3Last Post: 13th Nov 2008, 08:57 -
Question about capturing VHS tape to .avi file
By rfdillon in forum Capturing and VCRReplies: 6Last Post: 27th Jul 2008, 00:44 -
Question about color space using a DV camcorder for capturing VHS
By binister in forum Newbie / General discussionsReplies: 16Last Post: 12th Jan 2008, 18:14
