hello everyone
my band recently played a show. we got it on video tape and we want to take the audio from the video files, and make audio cds with them. how do i go about getting the audio from the video. if i have to convert the files from mpeg to avi i know how to do that. i just need help on how to get the audio track seperate from the video. thanks
You said "on video tape" then "MPEG".
What kind of tape? Just exactly what format are they in now?
See http://www.terraguide.com/Formats.html
Anyway, unless it's already in a digital format, probably the best way is to just connect RCA leads from the videotape deck to the audio in of a PC (maybe you need a jack that converts it to a 1/8" plug).
Then play the tape and record with, eg, Audacity. Edit to taste, divide into tracks, save to WAVE.
Almost every CD burning app will have a "wave to audio CD" module.
(In ImgBurn this is "Make CD Cue file".) -
You can demultiplex the audio from the mpg using for example tmpgenc, under file->mpeg tools->simple demultplixer. Then add the audio file in your audio cd burning app.
Or use goldwave and open the mpg and it should be able to just open the audio, save as an wav. Burn it.
Or use avidemux, open the mpg, under audio choose wac pcm and then audio->save as a wav file. -
Audacity can also open AVI and MPEG files directly if you have the FFMPEG binary for Audacity installed ( http://lame.buanzo.com.ar/ ).
"Just another sheep boy, duck call, swan
song, idiot son of donkey kong - Julian Cope" -
This app/tool can be used to extract audio from video files, and convert the audio to several formats..
http://xrecode.com/" Who needs Google, my wife knows everything" -
hey thanks guys for all your help. you guys are awesome. i havent tried to do it yet but i will get to it in a few days when i get the mpeg files from my friend. thanks again
Taking out the second audio?
By raitono in forum EditingReplies: 22Last Post: 25th Jan 2011, 14:12 -
Convert Audio within a Movie File
By nw in forum Newbie / General discussionsReplies: 3Last Post: 6th Aug 2008, 11:31 -
taking audio from one movie to sync in a movie
By bigdaddykane in forum AudioReplies: 9Last Post: 28th Dec 2007, 14:40 -
burning a dual audio file
By imkool in forum Newbie / General discussionsReplies: 3Last Post: 6th Aug 2007, 06:30 -
Taking Audio off of a DVD
By IrishToken in forum Newbie / General discussionsReplies: 5Last Post: 3rd Jul 2007, 21:08
