Guys,
I have Windows Explorer on my Desktop as a short cut. I continually use it. Is there a way to put C Drive as a shortcut on my Desktop. I would save soooooo much time.
Thanks you
orfa jackson
i use a top toolbar. left click on "my computer" and drag it to the top of the screen and release. works in XP, but you don't say which os you have.
Sure. Just open My Computer, right click and drag C Drive to your desktop, then click on Make Shortcut Here.
I found it easier to put c drive on the quick launch taskbar,easier to access.
I've never thought of a need to put C:\ on my desktop or Quick Launch bar but I do keep Windows Explorer on my desktop since I use it constantly and I have it set to open in "My Computer", showing all the drives. I also keep "My Downloads" on my Quick Launch bar for easy access while online.
To have Windows Explorer open showing all drives with C:\ expanded, right click on Windows Explorer shortcut, choose properties and enter...
C:\WINDOWS\explorer.exe /e,/select
...for Target:
Removed Esata drive and replaced with another drive. New drive is now unus
By cal_tony in forum ComputerReplies: 6Last Post: 7th Feb 2012, 15:17 -
DVD exploding inside the drive from a drive exceeding 24x. True?
By snafubaby in forum MediaReplies: 10Last Post: 5th Dec 2010, 19:05 -
Compress hard drive to save space/Index drive for faster searching?
By orfajackson in forum ComputerReplies: 3Last Post: 31st Aug 2009, 18:55 -
Time/Date Stamp - DVD, Hard Drive, and/or flash drive camcorders
By vanjh9 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 2nd Feb 2009, 19:38 -
Is It Possible to Make Multiple Drive Images on One External Hard Drive
By drstew in forum ComputerReplies: 17Last Post: 24th Nov 2007, 09:47
