My friend made a movie with a hard drive camera in HD. I want to edit in final cut so I have to convert. I can convert to DV using quicktime pro but the files come into final cut letterboxed. Quicktime is preserving the 16:9 ratio but final cut forces it to be 4:3 letterboxed. How do I get final cut to preserve 16:9?
jacob
Multimedia Design student getting an AAS in Springfield, Oregon. I like Gymnastics and DVD authoring. I think the two go nicely together.
what's the final output format going to be? if it's HD then rendering to SD and back is going to really lower the quality. it's already in a highly compressed long gop format. i'd edit it in it's original format and only re-render it once to it's final format.
if you can't do it that way, i'd render to a lossless intermediate format and then do the edits. DVavi isn't lossless. -
The final output will be a dvd. I can't edit it in its original format because final cut won't read mp4. There are a lot of special effects I want to put in this video and doubt I will be able to do what I want in a program designed to to edit mp4. I really want to edit in standard DV. Is DVavi the same as standard DV?
Multimedia Design student getting an AAS in Springfield, Oregon. I like Gymnastics and DVD authoring. I think the two go nicely together. -
DVavi is the type of DV used on a PC, mac's use DV without the avi wrapper. same content in a different format. DVavi has a widescreen 720x480 option, i don't know if mac's DV does.
isn't there an apple intermediate codec final cut could use that might be less costly in terms of quality loss? to keep it at 1920x1080 until the final render to dvd mpeg-2.
if not maybe render to a lossless codec like huffyuv or lagarith. you might need to render to 864x480 to keep the widescreen a/r.
Slow HD playback of MP4 1920x1080 files
By Mandy Frenkel in forum Newbie / General discussionsReplies: 5Last Post: 8th Feb 2010, 12:36 -
MP4 (x264 / AAC / 720x480) to MP4 (x264 / AAC / iPod res)
By GrayStrickland in forum Video ConversionReplies: 2Last Post: 15th Jun 2009, 11:20 -
Does any HDV do 1920x1080?
By David9799 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 16Last Post: 25th Mar 2009, 18:04 -
cant output 1920x1080 through vga
By sitlet in forum ComputerReplies: 13Last Post: 27th Jan 2009, 18:34 -
Why DVD (720x480) bigger than AVI(720x480)
By psxiso in forum Video ConversionReplies: 6Last Post: 3rd Feb 2008, 06:50
