Say, need an easy way to join avi/mpeg/vob files. Cutting/Splicing/cropping/joining, the more options the better but at least able to put two unrelated avi files together. And of course free is good. Tried looking through the forums but couldn't find it. Thanks.
AviDemux, VirtualDub...I'm surprised using 'Search' got you nothing...
" Who needs Google, my wife knows everything" -
Unrelated as in different specs? ie different dimensions, audio, fps, video codec, sampling rate...etc..? If so, you need to re-encodeOriginally Posted by nycdude
You can join them losslessly only if they are the same specs with the tools listed -
Fire up Avidemux-->File-->Open--> browse to first avi and import-->File--> Append, and import second avi...
However as noted above " You can join them only if they are the same specs"...
I was going to post a guide link, but looks like it's already done...
joining avi files
By dugen in forum MacReplies: 1Last Post: 11th Jun 2011, 12:47 -
Joining AVI Files
By wulf109 in forum Video ConversionReplies: 4Last Post: 4th Nov 2010, 14:17 -
Joining avi files
By carlmart in forum Video ConversionReplies: 13Last Post: 29th May 2009, 07:35 -
Joining avi files?
By tofuguy in forum EditingReplies: 4Last Post: 7th Oct 2008, 02:30 -
Joining avi files?
By t_jay17 in forum EditingReplies: 5Last Post: 18th Dec 2007, 12:22
