Read my blog here.
Frankly it's not worth the wear and tear on a writer to have to repeatedly reformat a disc and you're better off replacing it with a new one.
Also I keep a separate DVD+RW for images files, VIDEO_TS folders and data files so as to minimise the need to reformat. -
With ImgBurn, if I set the format as "ISO 9660 + UDF" I can use a DVDRW for either data or DVD video, without reformatting.Originally Posted by ntscuser
I also store backups on video DVDs when there is much left over capacity.
As for the OP: if neither ImgBurn nor Nero can format it, consider it dead. Throw it away. -
The disc's been erased no more than 4 times.
Thank you for the replies.
I've got four DVDRWs, various brands. I've used them dozens, perhaps hundreds of times. They are physically wearing out as I scratch them up through careless handling, and so I notice less reliable reading towards the end of the disc (i.e., near the outer edge, which is the most scratched area). A couple of times I've aborted a write and had to do a full erase before the disc could be used again. Nero seemed the most reliable for that, succeeding when ImgBurn (which I use for all my routine burning) failed.
Is it possible to erase a DVD+R?
By Han Solo1 in forum Newbie / General discussionsReplies: 5Last Post: 18th Aug 2010, 14:54 -
How to erase a DVD-R disk
By bryankendall in forum ComputerReplies: 5Last Post: 24th Dec 2009, 14:16 -
convertX waits for OK to erase DVD-RW
By lhughes in forum Video ConversionReplies: 4Last Post: 12th Sep 2008, 02:34 -
Can't erase my DVD-RW disc
By hurtstotalktoyou in forum DVD & Blu-ray WritersReplies: 4Last Post: 15th Nov 2007, 10:40 -
HELP - Can`t erase 10 dvd rw discs
By LOWTECH in forum DVD RippingReplies: 6Last Post: 13th Aug 2007, 15:28
