  1. Unable to unlock a VOB file using Smart Ripper. It appears to successfully see all the files but cannot unlock one file? Using a x8 speed DVD drive. could it be the drive, software or the DVD itself?
  2. Firstly it would be good to know what version of windows you are using!
    The type of problem you are having is common with windows XP users. With windows XP it does not have any built in ASPI drivers so therefore it is unable to unlock the files on the dvd in smart ripper. If i am right and you are using windows XP try downloading the ASPI device drivers and this should fix your problem.
    BHQ :roll:
  3. Running Windows ME (this is for a friend not myself). I will give this friend the ASPI Drivers which i recieved recently and see if they work, any other reasons why this would happen though?
  4. Member spidey's Avatar
    Apr 2001
    U.S.A.
    Do a search for ForceASPI I do think it's in Doom9.org's site too.
    Also, before you rip the movie, open it up in your software player and let it play for 30 seconds. Shut down your player, then boot up SmartRipper. The player will open the volume......
    ~~~Spidey~~~
    "Gonna find my time in Heaven, cause I did my time in Hell........I wasn't looking too good, but I was feeling real well......" - The Man - Keef Riffards
  5. OHHHH MY GOD HELP ME IM STUCK IN A SPIDER WEB!
    LOL
  6. u cannot unlock a dvd if more than one prog that can access the dvd drive is open such as the following-
    Smartripper open with-
    ANY software dvd player
    Any other type of video player
    Any prog that u are reading the cd in or access files on it other than windows explorer or my computer.
    ShiZZZoN PzN
    Everyday is another payday and I am one step closer to becoming the one.
  7. I have XP and wnaspi32.dll and Wnaspi32.w98.dll are the 2 aspi's i have to run 'dvd decrypter' but :evil: BEWARE :evil: I tried to force aspi and my disk drives became very choosy about what cds they would see and i ended up formatting because aspi is hard to properly uninstall, The uninstall that comes with it doesnt work well with xp.
    I got around the whole problem by actually finding the two dll's above and instead of installing them I put them in the folder with the dvd decrypter and nothing else
