I know I can use DVD Shrink to cut out a piece of a DVD. But if I want to cut out several pieces, how can I do that in one go? Or is it necessary to cut out one piece, reauthor and then cut out another piece and reauthor?
Results 1 to 10 of 10
Or drag the same title across multiple times and cut each part. However you end up with multiple titles as output. Shrink isn't really designed for editing, just top and tail trimming.
Better off using VideoRedo or Womble Mpeg Video Wizard or similarRead my blog here.
I used DVD Shrink to edit all my Voyager recordings.
I left the 'fade to black' (and in some cases saved the black as a title) before each commercial and this eased the transition as each title started playing. -
It's not as hard as it sounds. DVD Shrink 'remembers' where you last cut to so its fairly easy to measure the next piece and so on.Originally Posted by jimdagys
I'm amazed at the sudden desire to use a transcoder tool as an editor.
I also use it routinely to extract image files and strip audio streams but very, very seldom to shrink DVDsOriginally Posted by lordsmurf
I just want a quicky way to take a DVD and delete several parts, keeping audio and subtitles in sync. Video Redo doesn't allow to input the DVD, only the mpeg2, so the subtitles have to be dealt with separately, something I don't want to do.
Can you give me the steps how to do that with Video Redo? I see a lot of problems. I think Video Redo only allows you to input 1 VOB at a time. OK. If I edit the VOBs, then the original IFOs won't match the VOBs. I would have to reauthor the DVD from the VOBs. How do I do that?
You have answered your own question, really. VOBBlanker is a handy tool in some of these situations.
However I would rather do that than end up with a disc that is split into tiny titles with pauses in between edits.
Then again, I have never had the need to edit commercial discs in this manner . . . . . . . . . .Read my blog here.
Looking for low cost editor that can make multiple cuts and splice
By jimdagys in forum EditingReplies: 4Last Post: 11th Dec 2011, 12:33 -
Question why edges cuts off
By tofuguy in forum Authoring (DVD)Replies: 2Last Post: 26th Oct 2008, 03:09 -
dvd shrink: single large file or multiple small files
By avextraxjp in forum Newbie / General discussionsReplies: 1Last Post: 16th May 2008, 22:43 -
Searching program for multiple cuts/splits in Mpeg-files
By tomk in forum EditingReplies: 1Last Post: 5th May 2008, 04:48 -
DVD shrink fails to rip home recorded dvd in multiple sessions
By sybariten in forum Authoring (DVD)Replies: 9Last Post: 21st Aug 2007, 22:42
