i just downloaded the latest version of dvdfab 6.0.1.0. and tried to rip a movie, however the quality that came out of it is unwatchable. (anytime there is motion u can see alot of lines)
what am i doing wrong? am i supposed to use another decoder instead of the dvdfab one?
Did you just rip, or rip and convert ?
If you just ripped, then you have an interlaced source, and you need aplayer that better handles interlaced playback on the PC. You will not notice these problems when watching on a television.
If you have converted to another format then I suspect you need a better tool. I have never seen a good encode out of DVDFab. I use it only for ripping because it's encoding, especially of interlaced source, is horrible.Read my blog here.
In the settings it may have defaulted to DVD 5 rather than DVD 9, in which case the ripped files may be shrunk to fit on a DVD5 disc. If your original is closer to 9gb could produce an inferior result.
yea the default was set to dvd5
i changed it to dvd9, and will try to compress with shrink instead
HD to DVD finial quality results?
By birdfeeder in forum Newbie / General discussionsReplies: 25Last Post: 7th Aug 2012, 10:13 -
DVD ripping: does DVDFab give the best picture quality?
By Tom80112 in forum DVD RippingReplies: 25Last Post: 21st Feb 2010, 05:24 -
why is my video quality so horrible?
By crazymonk848 in forum Newbie / General discussionsReplies: 10Last Post: 21st Mar 2008, 13:23 -
Horrible audio quality when trying to capture from cvbs
By yadav in forum Newbie / General discussionsReplies: 1Last Post: 19th Nov 2007, 12:59 -
DVDFAB bad quality rips
By kidcash in forum DVD RippingReplies: 16Last Post: 19th Sep 2007, 02:46
