I went to China, and bought a ton of DVD's recently. The DVD's are really good quality, but they have chinese subtitles at the bottom already in the movie. It's not like something that can be deactivated, it's in the actual movie. whenever I try to deactive it, it says "no subtitles are present in this movie". So anyways, is there a way I can get rid of those and rip them, and make svcd's out of it? A setting I can mess with that would just cut the chinese out of it? the characters are below the action of the movie, on the black part, so it seems doable, but I'm not sure.
Well if the characters are in the black part then yeah, you can just crop them out. Rip the DVD, then run DVD2AVI. Under 'video' choose 'clip/resize.' A dialog box will appear, click the top right button to enable the crop window. Drag the preview bar to a part of the video with subs and a bright back ground (to make sure you cut all the black), and crop it out.
You can see directions (with screen shots) at:
http://www.flexion.org/video/DVDConv/DVD2AVI/dvd2avi-clip/ -
thanks for the help man! I was all disappointed because of the chinese characters, but it's all good now.
Converting MKV (Get rid of subtitles)
By kpat99 in forum Video ConversionReplies: 3Last Post: 4th Feb 2012, 08:50 -
How do I strip and get rid of Audio Streams and Subtitles in MKV x264 files
By whachano in forum Video ConversionReplies: 1Last Post: 8th Aug 2010, 00:44 -
Need help getting RID of subtitles in wmv (Windows Media Encoder)
By BooBerry in forum Video ConversionReplies: 4Last Post: 6th Feb 2010, 09:58 -
Getting Rid of Subtitles
By macbuz in forum MacReplies: 4Last Post: 16th Jan 2009, 19:09 -
quick question in regards to subtitles
By greymammoth in forum ffmpegX general discussionReplies: 3Last Post: 2nd Jun 2007, 13:34
