Hi I have recording a performance and I can hear a very irritate buzz in the background.
I can guess that is some fan that have make it to the microphone.
Is it possible to filter and remove the buzz without destroy the sound to much?
The buzz is on the same frequency all the time and it drive me crazy.
You can try it with an audio editor, which will probably give better results than vegas studio, then re-import the modified audio back into your project
You can try audacity (free) or soundbooth, audition , goldwave, etc...
If the buzz is distinct & repetitive , you should be able to capture an audio noise footprint and remove that from the main track with the noise reduction filters. -
thanks for you replay
yes I going to try that. I remember I did try that long time ago when I did recording a sound. The only problem is that it even remove some of the frequency that should not remove
But I going to give that a change because what I have found that is the best idea. -
The key is to capture the noise footprint from a section that has just noise, not the stuff you want to keep, because most noise reduction will try to digitally subtract this noise footprint. (you can try to find it visually on the waveform, while previewing. e.g. it might be a section where there are no vocals or a break in the music, where only the background noise persists)...I hope this makes sense...
You have more control over what gets removed (and better quality) with the more expensive editors, and usually worse quality with free ones , of course.
Vegas Movie Studio HD Platinum 10
By jjblackisback in forum SubtitleReplies: 3Last Post: 26th Apr 2011, 21:28 -
Movie Studio HD PLatinum adequate after Vegas 7 ?
By Prieur in forum EditingReplies: 3Last Post: 25th Feb 2011, 11:38 -
Vegas Movie Studio Platinum 10.
By EagleW in forum EditingReplies: 0Last Post: 15th Jul 2010, 21:03 -
What is the difference between Vegas Pro and Vegas movie studio platinum
By jbitakis in forum Newbie / General discussionsReplies: 4Last Post: 18th Feb 2009, 01:41 -
Vegas Movie Studio 8 Platinum Music/Sound effects
By Nuke Shower in forum AudioReplies: 3Last Post: 21st Apr 2008, 01:58
