May peace be upon you
I have a little problem with avc/aac videos since I can't find any tool to cut those videos I'm constrained to convert them to avi (or something else) in order to do it (avidemux seems to ignore it).
Do you know a tool to do it, thanks a lot.
what container? mp4,ts,m2ts,mkv?
and I guess you just want to basic cutting and no advanced stuff? -
Since there are many spec that I ignore(the container is FLV),here is the result :
Well if the advanced cutting is available it will be helpful but basic will do (cutting by duration).Format : Flash Video
File size : 199 MiB
Duration : 38mn 3s
Overall bit rate : 730 Kbps
starttime : 1.974
totalduration : 2283.016
totaldatarate : 730.765
bytelength : 208378784.000
canseekontime : Yes
sourcedata : B4A7D0244
Video
Format : AVC
Format profile : Main@L3.0
Format settings, CABAC : Yes
Format settings, ReFrames : 3 frames
Muxing mode : Container profile=Unknown@3.0
Duration : 38mn 3s
Bit rate : 625 Kbps
Width : 630 pixels
Height : 350 pixels
Display aspect ratio : 16/9
Frame rate : 29.970 fps
Resolution : 24 bits
Colorimetry : 4:2:0
Scan type : Progressive
Bits/(Pixel*Frame) : 0.095
Stream size : 170 MiB (86%)
Audio
Format : AAC
Format version : Version 4
Format profile : LC
Format settings, SBR : No
Duration : 38mn 3s
Bit rate : 96.0 Kbps
Channel(s) : 2 channels
Channel positions : L R
Sampling rate : 44.1 KHz
Resolution : 16 bits
Stream size : 26.3 MiB (13%)
Many thanks for the attention. -
the problem is most software doesn't have an updated splitter for this format. This topic has been discussed in several threads if you search.
flvextract to demultiplex into raw streams, use mkvtoolnix, or yamb to re-wrap into mkv or mp4, then you should be able to use avidemux to cut, or even mkvmerge by timecodes (if in .mkv container). If the timecodes generated by flvextract show varying intervals, you have a VFR (variable frame rate) flv. AVI container doesn't support VFR, but mkv , mp4 do.
This won't be frame accurate, it will only cut on the nearest IDR frame. There are no frame accurate h.264 cutters (unless you re-encode) -
Thanks for everyone it worked just fine. 8)
115 "Did you think that We had created you in play (without any purpose), and that you would not be brought back to Us?"
Al-Mumenoon, Chapter #23, Verse #115
How to open AVC and AAC in VirtualDub (AviSynth/DShowPlugin)?
By klischee in forum EditingReplies: 37Last Post: 8th Aug 2014, 03:38 -
Flv with avc and aac coding.How do i join them anyway?
By noeway in forum EditingReplies: 1Last Post: 19th Apr 2012, 05:13 -
Editing MP4 files with H.264 (AVC) video and AAC audio
By Ahari in forum Newbie / General discussionsReplies: 4Last Post: 16th Apr 2012, 17:30 -
FF AAC & H.264 AVC - Sony Vegas woes....
By andwan0 in forum Newbie / General discussionsReplies: 4Last Post: 6th May 2011, 06:41 -
How to edit MP4 with AVC video and AAC audio?
By nonexistent_entity in forum Newbie / General discussionsReplies: 3Last Post: 25th Sep 2009, 07:58
