    May 2009
    Australia
    I have a Sony video camera and wish to copy footage to my Sony Vaio laptop. I have tried transfering footage with the software the laptop came with, however it doesn't include the date and time of the footage taken - this is a must. I then wish to burn footage to DVD. Any info re this topic would be greatly appreciate. Thanks
    Apr 2004
    Miskatonic U
    If this is a Mini-DV camera then the date and time information are stored in the file, and can be extracted as subtitles which can be added during the authoring stage, or hard-burned during the encoding stage.
    If it is a HDD based camera then the process seems to be on that is not addressed (there was another post on this recently that is, I believe, still unresolved).
    The only other option is an analogue transfer, which requires specialist hardware and will be of lower quality.
    Read my blog here.
    May 2009
    Australia
    Hi thanks for your quick response,
    The camera is a Mini DV - how do I extract them as subtitles (as you may have guessed, I lag in the correct know-how of computing. If you can help thats cool, if you cannot go into it,thats also cool and thanks thus far.
    Apr 2004
    Miskatonic U
    I haven't used them, so you will have to do some research (start with the comments and scores), the following is a short list of candidates
    DV Sub Maker
    DV_Datecode
    DVDate
    Visual DV Time Stamp
    Work out which approach you want to take (subtitle versus hard coded) and pick a tool to play with
    Read my blog here.
    May 2009
    Australia
    Thanks so much.
