Hi;
I used TMPGEnc Editor's MPEG tools to demultiplex a vob file into the following:
However, after editing the MPEG video to fix some small artifacts in the beginning (I basically replaced the damaged frames with identical frames from another DVD of the same series), I couldn't find a program that would include the .dat files when multiplexing back to VOB (as a matter of fact the only program that I could find that would even mutiplex into VOB was ImagoMPEG-Muxer!).Code:VTS_01_1.m2v VTS_01_1.ac3 VTS_01_1-01.ac3 VTS_01_1-0xBF.dat VTS_01_1-0xBE.dat
If any of you could point me to a program that will mux all of these files into VOB I will be very grateful!![]()
I'm not sure; I've included a screenshot showing the file size of the various items. When played in mplayer/VLC it doesn't show anything at all...it loads, shows nothing (no screen at all) for a few seconds, and then closes.
You're probably wondering why I don't just forget about them, but I want the final VOB to be close to identical to the one I started off with after replacing the damaged frames. And of course they probably serve some obscure purpose that would render the DVD obsolete if I were to remove them.
I mean something demultiplexed them...so I'm thinking there has to be a way to put them back in VOB.
Edit: They're not from VCD; they were ripped from a DVD5.
Finally, someone else using the wonderful little tool called TMPGEnc MPEG Editor.
Those .dat files mean nothing. Just disregard them as they're probably padding packets or container overhead or whatever.
As for muxing (multiplexing) into a .vob, you don't really have to unless you're authoring. You can just mux into an .mpg file in the meantime. When you're ready to author, just load these streams into your author app (either the .mpg file straight or the demultiplexed .m2v/.ac3 separately depending on the app) and it will create the DvD structure for you - all VOBs, IFOs and BUPs. (No .dat files though - a non-issue.)I hate VHS. I always did.
after vob Demux the m2v and ac3 have duration difference
By yozloy in forum Authoring (DVD)Replies: 1Last Post: 23rd Jan 2010, 01:45 -
Take a .VOB or .M2V file + inverse telecine it so output is .VOB or .M2V?
By DrGori in forum Video ConversionReplies: 20Last Post: 10th Oct 2009, 20:25 -
Demuxed VOB into M2V and AC3 -- Sync issues
By jj_30 in forum ProgrammingReplies: 0Last Post: 16th Jul 2009, 12:38 -
free m2v+mp2 multiplex (other than ImagoMPEG)?
By tff in forum Video ConversionReplies: 3Last Post: 4th Jun 2009, 09:31 -
Multiplex SD Mpeg with ac3 audio
By hartless in forum DVB / IPTVReplies: 8Last Post: 9th Sep 2008, 06:59
