I recently upgraded to the rc of windows 7 from vista ultimate and I am having a little trouble with 2 programs with alcohol 120 my virtual drives are gone and when it starts it says something about drivers cant load and tmpgenc xpress will not start. Does anyone know how to fix these problems?
Are you running them as administrator(right click on the shortcut and choose run as administrator? or try run them in compatibily mode, right click on the shortcut and choose properties and under compatibility enable run this program in compatibility mode for and choose windows xp or windows vista.
I have tried everything to get them to work since they don't seem to be completable with windows 7 does anyone know of another virtual drive or mount program and a video encoder that work with windows 7?
video encoder? what exactly do you want to convert? Many free tools works fine for me, like handbrake, xvid4psp and mpeg streamclip.
And try virtual clonedrive as virtual drive.
edit: Yep, clonedrive works on my windows 7 rc. -
The release candidate is not meant for a production machine. It is still in evaluation status. You should wait until it goes RTM later this year. If you have another operating system, I suggest you use that for now.
Believing yourself to be secure only takes one cracker to dispel your belief. -
Originally Posted by Dv8ted2
This doesn't work, that doesn't work..Please help me get this (insert application) working under a BETA operating system.
Screw MS and their crummy BETA OSs
Why can't MS get this stuff to work
I'm not pointing this to the OP, just in general.
Windows DVD Maker Size Questions...
By alank2 in forum Newbie / General discussionsReplies: 3Last Post: 24th Jan 2010, 16:05 -
Windows 7 64-bit questions???
By HotDamn! in forum ComputerReplies: 6Last Post: 15th Jan 2010, 18:01 -
windows 7 questions
By mysts in forum ComputerReplies: 4Last Post: 3rd Jul 2009, 21:34 -
Linux questions from a Windows/OS X user
By LSchafroth in forum ComputerReplies: 18Last Post: 2nd Apr 2008, 23:36 -
Windows 2000 Questions
By dafoe in forum ComputerReplies: 2Last Post: 21st Dec 2007, 16:31
