i wnat to use a philips dvd 622 to look at vcd cd īs . With other standalone dvd player like the very cheap cyberhome etc. itīs not a problem but with the DVD 622 i see permanent look ups. :evil: Any hints (exept to sell the dvd) are wellcome. The vcd uses the following parameter:
MPEG-1 352x288 25fps CBR 1150kbps, Layer-2 44100Hz 192kbps (PAL)
Hi!
I had the same problem with both vcdīs and svcdīs.
I changed the burning speed from 8x to 4x and the movies didnt freeze a single time...
i dontīnow if it will work for you but give it a try. -
I think I already answered this for you in http://www.vcdhelp.com/phpBB/viewtopic.php?t=79743. So why sending a new post on a different section?
Problems with Philips +R DL discs
By carlmart in forum MediaReplies: 17Last Post: 29th Sep 2010, 08:24 -
Philips DVD 622 ? about picture on other region dvd's
By gdave53925 in forum DVD & Blu-ray PlayersReplies: 4Last Post: 18th Dec 2007, 10:07 -
Philips dvdr3360h problems
By rooboy in forum DVD & Blu-ray RecordersReplies: 1Last Post: 4th Oct 2007, 11:25 -
Philips DVDR 610 Problems
By Rachel85 in forum DVD & Blu-ray RecordersReplies: 10Last Post: 24th Jul 2007, 09:36 -
Problems with philips dvd-622
By angelarumble in forum DVD & Blu-ray PlayersReplies: 2Last Post: 8th Jun 2007, 14:38
