I used to have the auto update set for every day. Now I changed it to once a week. Problem is, during the auto update, it takes about 15 minutes to complete and during that time I can hardly use the computer. I don't understand why it needs to update seemingly so much data, and why the computer slows down so much during the update. Even if I download 200kbps from Rapidshare, the computer still operates normally.
It needs to update daily because new virus signatures are released daily. If you change it to update weekly, then it has to do a weeks worth of updates. That is why it takes you so long. My advice would be to set the update time during a period when you know you are not going to be using your computer. Set it for 2am or something, then you can do whatever you want to do.
Believing yourself to be secure only takes one cracker to dispel your belief. -
Downloading and updating signatures should be pretty painless. But be default McAfee used to then scan all files. Which is likely what is causing your slowness.
I quit using McAfee and Norton long ago because they are resource hogs, even when they aren't doing stupid things like this.Google is your Friend -
Realtime protection is not stupid. It saves you if you have somehow been infected.Originally Posted by Krispy Kritter
If you have a computer that is not a dinosaur, the scanning is an invisible process, and you hardly notice it.Believing yourself to be secure only takes one cracker to dispel your belief.
Update on ATI TV Wonder 650 USB Auto Gain Control (AGC) Issue
By Mini-Me in forum Capturing and VCRReplies: 7Last Post: 22nd Aug 2013, 09:39 -
Question on WME9 and auto restart
By ml41782 in forum Video Streaming DownloadingReplies: 0Last Post: 7th Jan 2011, 12:35 -
Intel to buy McAfee for $7.68 billion
By MJA in forum Off topicReplies: 12Last Post: 23rd Aug 2010, 00:23 -
Another troubled titan: Intel buys McAfee...why?
By ahhaa in forum ComputerReplies: 1Last Post: 21st Aug 2010, 19:05 -
Telling McAfee to Shut Up
By ahhaa in forum ComputerReplies: 9Last Post: 23rd Aug 2007, 18:13
