Hey Guys,
*Total* newb here. I've done my fair share of using Handbrake and MTR, but nothing to do with MKVs.
I have an MKV which has an audio file, however its in the wrong language.
I also have a separate AC3 audio file with the correct language.
All Google is bringing back is that I can use MKVMerge or MKVToolnix to either remove one language and add another, or separate the video and compile it into a file with the "new" language.
The problem I'm having is that the above mentioned apps won't even open on my Mac.
I have a brand new Unibody MacBook Pro - so it can't be that my hardware can't cope. Someone said I need to compile my own version of the app - no idea what this means.
What can I do to make the apps work, or, is there a different, simpler solution?
Thank You
PS: Treat me as a *total* newb as though I know nothing![]()
http://www.bunkus.org/videotools/mkvtoolnix/downloads.html#macosx links to several pre-compiled Mac binaries. Download one of the Leopard ready versions. Note : the first one appears to be command line only, but is more recent. The second is an older version, but appears to have a gui.
Read my blog here.
The moment I open it, I see the window MKVMerge GUI v2.3.0 Freak U - and then a message pops up:
The Application MKVMerge quit unexpectedly - eventhough the window is still open.
Then, when I try and add a MKV file I get:
File Identification Failed
*file location and name*
Return code: -1 -
What if you tried a different tatic?
With Perian 1.13 installed, and Quicktime Pro,
you opened the MKV file, went to Movie Properties,
and disabled the language track you do not want?
And then, with QT Pro still open, opened the AC3 file,
and first copy the video, and then selected the audio
track, and then went Edit-->Add To Movie?
This should put the Video and the AC3 audio into one container,
and from there, you could then
Save AS-->Quicktime Movie-->Self Contained, and with no re-encoding,
it will put both audio and video
into a new QT .mov container.
The only Downside I see is that (a) you'll need QT Pro,
and (b) the following Codecs installed:
1. Perian 1.1.3
2. QT AC3 codec v0.4b1 or higher
and it will take a while for the whole mkv to load in QT Pro, but this should work."Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User -
For some reason, a build from September 2008 works.
Or at least it has through one restart, and done about 3 movies.
If I have trouble again, I'll definitely try it your way.
Thank you
How to add audio tracks to MKV video?: mkvtoolnix problems
By LanguidLegend in forum Newbie / General discussionsReplies: 2Last Post: 12th May 2011, 12:15 -
MKV file help using MKVtoolnix
By KoolK in forum Newbie / General discussionsReplies: 1Last Post: 11th Oct 2010, 21:16 -
Making a dvd with an english track from a mkv file that has both japanese and english
By andyjc in forum MacReplies: 0Last Post: 12th Feb 2010, 10:41 -
MacOS 10.5 > mkvtoolnix > Converting MKV (H264/AVC+AC3) to DVD
By Savant2k6 in forum MacReplies: 0Last Post: 16th May 2008, 16:58 -
how to add ac3 to mkv
By adaz in forum Video ConversionReplies: 11Last Post: 16th Apr 2008, 01:32
