I just got a response back from cyberlink's tech support. if you want to change when powerVCR splits up your mpgs (default is every 600 megs) add this to your registry:
REGEDIT4
[HKEY_CURRENT_USER\Software\CyberLink\PowerVCR II]
"MaxRecSizeMB"=dword:000007d0
the value is in Hex.. in this case it's set to 4000 decimal, which is 4gigs (fat32 file limit on win2k/xp systems).. if you're using ntfs then feel free to up this some more, and if you're using fat32 on a win98 machine, drop it down to 2gigs (limit on fat32 in win98)
Originally Posted by REDi
This tip is to get PowerVCR to do bigger files is nifty though, thanks!As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war." -
maybe i was thinking of win95's fat 32 being limited to 2 gigs.. maybe i'm totally wrong . oh welll..
as for the powervcr thing.. i can't believe that a) there's no option to set the size to split by and b) that by default there's no reg key to set teh size, so it implicitly sets to 600 megs, and without an exisitn key in the registry, there's no way for a user to figure out how to change this..
VobBlanker DVD Split- Automatically jump to Split Title
By src2206 in forum DVD RippingReplies: 12Last Post: 11th Dec 2008, 07:58 -
Powervcr II 3.0 Deluxe
By vijaye05 in forum Capturing and VCRReplies: 1Last Post: 7th Oct 2008, 04:30 -
Best Captures for RF?
By therock003 in forum Capturing and VCRReplies: 10Last Post: 29th Jul 2008, 14:56 -
Split Mpeg or convert to AVI then split. What to do?
By oldfart13 in forum Video ConversionReplies: 4Last Post: 24th Mar 2008, 00:00 -
Procoder split/split by size/media query
By kippard in forum Authoring (DVD)Replies: 7Last Post: 17th Nov 2007, 22:35
