I hope you can give me some help!
I'm trying to convert a European PAL DVD to our (USA) NTSC format. I'm using Movavi and had not problem doing the actual conversion however the PAL disc is in Spanish. On the DVD case it says that it also contains the English version.
How do I find this and burn that version to DVD?
Thanks in advance, I'm in a bind, this is a birthday present and I'm running out of time.
Regards,
Bald Bill
Unless the English version is a different cut of the film, all you are looking for is an audio track, in which case you what you needed to do was rip the video with the English language track, and convert that. I don't know MovAVI or how good it's format conversion is, but you probably need to go back to the ripping stage and start again to get this right.
Read my blog here.
Thanks!
I found a little blue arrow, that when clicked on showed me the audio options.
I'm re-ripping it now.
Thanks!!
Bald Bill
Changing AVI Properties (Resolution, FPS etc) NTSC>PAL
By skywalka in forum Video ConversionReplies: 4Last Post: 7th Mar 2011, 20:45 -
Converting PAL to NTSC and rip PAL Audio to WAV in VLC
By happydog500 in forum Video ConversionReplies: 1Last Post: 8th Aug 2009, 01:47 -
changing sup to srt for FAVC (Pal to Ntsc)
By spiritgumm in forum SubtitleReplies: 6Last Post: 13th Jan 2009, 11:57 -
PAL DVD to NTSC DVD: CCE is changing resolution (720x480 to 720x576). Argh.
By Colmino in forum Video ConversionReplies: 2Last Post: 9th Jan 2009, 19:15 -
Changing PAL to NTSC on a Samsung DVD-HR753
By sni6ero in forum DVD & Blu-ray RecordersReplies: 2Last Post: 21st Jul 2008, 11:34
