Hi everyone, I hope s.o can help me out.
I downloaded some made-in-USA dvd music from the web. I use the mpg2cut2 software to cut out a bunch of clips i like. then I use this mpg2cut2 to join them together to make a 4gb mpg clip.
then I use dvdflick to authorize, this dvdflick does not take the whole 4gb clip due to unsupported format. this is strange because I suppose that all the small video clips are in mpg after being processed by mpg2cut2.
then I demux this 4gbclip before using the muxman in the gfd software to authorize again. the gfd/muxman accepts the whole 4gb clip but the video and audio is out of sync.
Thanks for all responses.
Results 1 to 1 of 1
Help to convert MPG to an Xbox 360 Format?
By lovelylisa in forum Video ConversionReplies: 7Last Post: 13th Jan 2012, 02:23 -
Please help. Problem Converting CCTV DVR mpg file to dvd format with audio
By sinisterzane in forum Video ConversionReplies: 4Last Post: 16th Jun 2011, 18:28 -
Is MPG the best format for saving DVD recordings?
By sldvd in forum Newbie / General discussionsReplies: 3Last Post: 12th Mar 2010, 06:11 -
i captured a video from reciever in .mpg format, [ a conversion problem] !!
By aSem-1 in forum Newbie / General discussionsReplies: 6Last Post: 28th May 2009, 16:22 -
best format/codec for compressing an mpg???
By cduval04 in forum Newbie / General discussionsReplies: 1Last Post: 28th Dec 2007, 19:31
