I am in the market for a 22"~26" TV to replace my computer monitor.
For the LCD TVs, the better looking TVs normally has about 450~500 cd/m2 brightness.
I researched a bunch of LCD TVs like ViewSonic, Samsung, element, Sanyo...
I found out that most Toshiba, Samsung, Viewsonic has higher PC resolution like 1680x1050, but their brightness is only 300~350 cd/m2. Is this too dim in a bright room ?
I did got a Samsung 24" TV/PC monitor, and the display is really sharp, even with 300cd/m^2.
what the heck is 300cd/m^2, anyway ? I've ben seeing that figure more and more
-vhelp 5142 -
Cd = candela. m^2 is "meters squared" (a unit of area). So a Cd/m^2 is a brightness measure (specifically, per unit area).
120-140 cd/m2 is normal for a calibrated monitor with office lights. 300 cd/m2 is too bright, but if you can turn down the brightness it would be fine.
But why a TV as computer monitor?
I would buy the Dell 2209WA e-IPS monitor.
http://www.cnet.com.au/dell-2209wa-339294389.htm -
1. If you read the spec off flat screen TV. They are either ~500cd/M^2 or 300cd/M^2.Originally Posted by ronnylov
2. I am using a PC monitor ( 1920x1200) as a TV.
You seen to everything backward.
Is A $300 Camera Any Good
By budwzr in forum EditingReplies: 5Last Post: 10th Jan 2012, 22:11 -
ADVC-300 + JVC S3911U a good choice for old home movies?
By treefrog in forum RestorationReplies: 6Last Post: 2nd Aug 2011, 11:52 -
Good consumer LCD TV for VHS transfer without auto color/brightness
By OldMedia in forum RestorationReplies: 0Last Post: 1st May 2010, 02:02 -
sudden brightness jumps
By carmatic in forum RestorationReplies: 14Last Post: 24th Jan 2009, 12:05 -
MPEG Reencoding with more brightness
By Ricardogn in forum Newbie / General discussionsReplies: 18Last Post: 13th Jan 2008, 00:24
