  1. I have a Mac mini (last years model) attached to my Samsung TV (Model LN32A450) and use the Samsung recommended screen resolution of 1360x768. It works great with Boxee and I watch a lot of Netflex movies that way. When I upgraded the OS from 10.5.6 to 10.5.7 it changed the screen resolution to a much higher resolution -1600 something x something else. I went to System Preferences to select 1360x768 but it wasn't there! I could not find a satisfactory resolution and had to reinstall OS 10.5.6.
  2. Member terryj's Avatar
    N35°25.24068, W097°34.204
    This is a BIG problem listed on the front page of MacFixit.com.
    If you need the resolution, you'll have to downgrade to
    10.5.6., otherwise live with the higher 1600 x 900 resolution setting.
    "Everyone has to learn, so that they can one day teach."
    When I'm not here, Where can I be found?
    Urban Mac User
