Sorry for this - only makes sense to ppl from UK over the age of 25:
/7 You can do it if u Bin and Cue it /7
Try StreamFab Downloader and download from Netflix, Amazon, Youtube! Or Try DVDFab and copy Blu-rays!
Results 31 to 47 of 47
@ember - nice one!
@hvr & @disturbed1
Turned the PBC off - no difference whatsoever apart from nothing at all played. I pressed "Play" and the DVD player said it was playing (however nothing was seen or heard). I pressed "Stop" and the counter went to 8:09!!(??) Anyhow thought that maybe I should burn a real CD-R istead of CD-RW but still on both my players the same problem.
So the interesting thing now would be find out - is it Nero that really can't process the bin files correctly or is it just a DVD Player problem - one is a Sampo clone, which will play normally everything. Any ideas guys? -
@hvr & disturbed1
Doh! For some odd reason I had corrupted (better said erased the whole original information in the cue file) - that's why nothing was seen of the clip examples.
Anyhow have successfully burnt the VCD demo and played it. Only with PBC off I could however access the clips.
So as I said in the beginning - Nero does burn the cue/bin files correctly - it just takes 2 secs off.
Just created a SVCD .bin and .cue using VCDImager, and tried to burn with CDRWIN. The CD won't play on my DVD player. Looked it on my PC, nothing is found except it has ~540M used. Then burn the .bin & .cue using nero5.5.30, the SVCD works fine on my DVD player. From my experience this time, I would like to say CDRwin also has problems.
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
Um, how can you say that Nero burnt it correctly? From what you just described, it completely stuffed up the VCD.
On the demo VCD, all clips should be selectable -- that was the point, so you could see if your player+TV could handle PAL, NTSC and NTSC-FILM.
If Nero incorrectly burns the tracks on a VCD by 2 sec (150 sectors) that is a HUGE problem. It may not matter much on a non-PBC VCD where you are just playing the tracks, but as you've seen, on a VCD that does use menus, they no longer work.
Regards.
Michael Tam
w: Morsels of Evidence -
Did you use a pirate serial number? If so you only have yourself to blame as Goldenhawk has outsmarted you.
Regards.
Michael Tam
Just thought I'd revive this topic a bit by saying I hate Nero now and yes I have EZCD destroyer/creator 5plat and GHawk's CDRwin...okay I'm done
sorry for the wasted post
r@yjr13 ¦-< what you lookin at¿ :o
¡Now selling audioly and visually challenged coasters, frisbees, and vanity mirrors! -
Yes and the moral of this story is Nero Sux when it comes to BIN QUE files.
@vitualis
So the PBC off thing is caused by Nero? As I understood disturbed1 he used CDRWIN and had the same problem. -
On 2001-07-26 09:41:34, aldus4 wrote:
@vitualis
?? I'm not sure what you are refering to.
As far as I can tell, dirsturbed1 said a few posts back that on a SVCD sample he burnt (CUE/BIN) with Nero came out stuffed (menus didn't work). But when he burnt it with CDR-Win, it worked fine.
You can turn the PBC off any disc so that it only plays back the video tracks.
Regards.
Michael Tam
>aldus4
as vitualis said
Nope not what I meant
I had the same problems as you with Nero, then I burnt the disc with CDRWIN. CDRWIN burnt the disc correctly, all menus, and extras worked correctly with CDRWIN, but not Nero.
Try it with CDRWIN, or Fireburner (I've tried Fireburner too, may switch to it).
<font size=-1>[ This Message was edited by: disturbed1 on 2001-07-26 10:29:10 ]</font> -
OK - misunderstood.
So, summing up - culprit is Nero i.e.
So Rule No. 241:
If you bin & cue it,
Don't let Nero do it!
How, you really dug up an old thread! This was when the Nero CUE/BIN burning bug was identified...
Yes, it got fixed -- somewhere around version 5.5.8.x I think.
Regards.Michael Tam
Originally Posted by vitualis
I arrived at this thread from a link on this page:
http://www.hvrlab.org/~hvr/vcdimager/nero_bug.html -
No need to apologise... I was just kind of surprised that this 2 year old thread was still around...
It brings back memories... Back in those days, it took a lot of convincing for Nero fans to understand that Nero couldn't burn CUE/BIN images properly. This was the thread where this was not only proved, but the exact problem was identified.
I think that hvr eventually contacted Ahead and this resulted in the newer versions of Nero having proper support for CUE/BIN images (well, mostly).
Regards.Michael Tam
cue and bin files
By natty in forum Newbie / General discussionsReplies: 2Last Post: 21st Jun 2011, 15:25 -
Having trouble with .bin/.cue files
By UncleBose in forum Software PlayingReplies: 8Last Post: 12th Jan 2008, 06:06 -
cue,bin converting to dvd?
By zziem in forum Newbie / General discussionsReplies: 5Last Post: 7th Aug 2007, 10:36 -
What files/settings do I need for bin/cue
By Choppa in forum Authoring (VCD/SVCD)Replies: 9Last Post: 23rd Jun 2007, 21:29 -
How to merge 2 cue/bin to one DVD
By motleycool in forum Newbie / General discussionsReplies: 5Last Post: 7th Jun 2007, 21:26
