Hello! I use Fraps to record ingame footages when I play World of Warcraft (WoW). My monitors resolution is 1280x800 and my WoW video settings are also set to 1280x800. I record at 30 fps with Fraps.
I then open the big AVI output file of Fraps in VirtualDub and Video-->Compression-->Xvid Mpeg-4 Codec --> Configure and I set the slidebar thing to maximum quality and a bitrate of 3000kbps. I then click OK until all the dialog boxes are closed then I go to File --> Save as AVI (F7) I enter the filename then click save and I wait until it's finish compressing. I do this to decrease the file size of the video.
The problem is this, the images below are screenshots when I played each AVI on fullscreen on Media Player Classic
Fraps AVI:http://img43.imageshack.us/img43/5425/fraps.jpg
VirtualDub AVI: http://img43.imageshack.us/img43/7060/virtualdub.jpg
As you can see, the movie "shrunk" after I compressed it with VirtualDub. What I want is the same resolution and good quality movie but with a file size that is not too big in comparison to the Fraps AVI
Results 1 to 9 of 9
I don't think this is it but check the pixel aspect ratio setting in Xvid before you encode. Make sure it's set to Square.
Also, open your Xvid encoded video in VirtualDub. Does VirtualDub show the black border? -
Pixel aspect ratio is set to Square and VirtualDub does not show the border of the Xvid encoded video. However, I've tried playing both files on different players, Windows Media Player, Media Player Classic, Zoom Player and the black border shows up.
General
Complete name : C:\Users\Joko\Desktop\1.avi
Format : AVI
File size : 12.8 MiB
Duration : 23s 867ms
Overall bit rate : 4 502 Kbps
Writing library : VirtualDub build 30091/release
Video
Format : MPEG-4 Visual
Format profile : Streaming Video@L1
Format settings, BVOP : Yes
Format settings, QPel : No
Format settings, GMC : No warppoints
Format settings, Matrix : Default (H.263)
Muxing mode : Packed bitstream
Codec ID : XVID
Codec ID/Hint : XviD
Duration : 23s 866ms
Bit rate : 2 951 Kbps
Width : 1 280 pixels
Height : 800 pixels
Display aspect ratio : 1.600
Frame rate : 30.000 fps
Resolution : 24 bits
Colorimetry : 4:2:0
Scan type : Progressive
Bits/(Pixel*Frame) : 0.096
Stream size : 8.40 MiB (66%)
Writing library : XviD 1.2.1 (UTC 2008-12-04)
Audio
Format : PCM
Format settings, Endianness : Little
Format settings, Sign : Unsigned
Codec ID : 1
Codec ID/Hint : Microsoft
Bit rate mode : Constant
Bit rate : 1 536 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Resolution : 16 bits
Stream size : 4.37 MiB (34%)
Interleave, duration : 34 ms (1.02 video frame)
Interleave, preload duration : 500 ms
The borders don't show when I play on VLC. I noticed the top and bottom borders are a bit lighter than the left and right ones when they do show up. How do I fix this?
Edit: I just converted to MP4, the borders show up. (top and bottom) -
If VirtualDub shows no black bars in the xvid encoded file then they are being added during playback. Normally I'd suspect a setting in the media player but you are getting the same thing in several players. That would imply a system problem. Have you tried updating graphics drivers?
hey when the video is done compressing i try to watch the new video that was compressed and it says " Classfactory cannot supply requested class."
whats the problem? -
From your screen caps it looks to me like you encoded the 1280x800 video in to a 4:3 frame. So the video was shrunk to about 1066x666 and placed into a 1066x800 frame with black borders added top and bottom. Then when you play that back the 1066x800 video is centered on your 1280x800 monitor and black bars are added to the sides.
Why didn't you just leave the frame size at 1280x800? If you want a smaller frame size you should just use a 10:16 aspect ratio frame size like your monitor. Like 640x400 or 960x600.
FRAPS audio problem
By terrypin in forum Newbie / General discussionsReplies: 0Last Post: 20th Feb 2010, 09:55 -
World of Warcraft newbie - back to life?
By yoda313 in forum Off topicReplies: 9Last Post: 22nd Oct 2008, 10:36 -
Fraps Record Volume Problem
By WolfyBrandon in forum Newbie / General discussionsReplies: 0Last Post: 4th Apr 2008, 06:41 -
Virtualdub capturing resolution problem
By bloodshed in forum Newbie / General discussionsReplies: 3Last Post: 15th Jan 2008, 12:07 -
Linux Noob and World of Warcraft
By Trident5 in forum LinuxReplies: 6Last Post: 1st Jan 2008, 06:02
